1/2 MD Plenum Spacer and Engine Cover.
Old Feb 1, 2010 | 09:01 AM
vietboi817's Avatar
I've read in numerous threads that the oem engine cover will not fit back on, so my question is, is there an aftermarket cover that would fit on after the installation? thank you fellow wise-people
Old Feb 1, 2010 | 09:40 AM
gary c's Avatar
I guess after reading enough posts about how the OE engine cover won't fit after the 1/2" MotorDyne spacer is installed....you believed us. What I did was to order a 350Z CF engine cover from Riverside Infiniti 800-919-8130. That still won't fit perfect so you'll need to enlarge on side with a Dremel tool, only takes a minute. Caution....you'll need to add a few rubber washers under the back to make it sit right and DON'T OVER TIGHTEN the 10MM nuts.
Gary
Old Feb 1, 2010 | 10:49 AM
Calvin's Avatar
Overglorified Altima
The OEM engine cover WILL fit with MD's 1/2" spacer. You may need to invert the grommets, but it will fit. It will rub if you still have your hood liner, but that won't cause any harm except for a couple rub marks on the cover.
Old Feb 1, 2010 | 04:28 PM
spinna001's Avatar
IT WILL FIT AS I HAVE IT ON. I did not have to modify a damn thing lol.
Old Feb 1, 2010 | 07:32 PM
NachoCheese's Avatar
How do you like the 1/2 anyways? I just bought one cuz I got it used cheaper than a new 5/16. Is it just bigger gains top end?
Old Feb 1, 2010 | 07:37 PM
vietboi817's Avatar
Thank you wisemen for your comments. I was thinking about replacing the OE cover with this http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123 I'll be keeping in mind what Gary suggested. Regarding the spacer, I haven't got the chance to pop it in yet. Still waiting for this cover to go through and grounding wires to come so I can install everything at once.
Raven7
Aug 14, 2015 04:40 PM
wuppiedog
Aug 7, 2015 11:16 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
joedaddy1
Jul 28, 2015 02:58 PM
