Problem with SPC
Old Feb 5, 2010 | 08:13 PM
TurK's Avatar
Unhappy Problem with SPC
I got the front camber kit installed with the hub shims.... driving off the shop my slip light is on and so is the abs....had to drive with the vdc off....now the vdc wont turn back on.....
Can anyone help?
Old Feb 5, 2010 | 08:29 PM
tragedycat's Avatar
Did you buy the revised edition camber arms? 350z and G35 sedans can use unrevised ones, but G35 coupe needs their own version with their own product # to avoid ABS sensor knocking problems.
Old Feb 5, 2010 | 09:32 PM
TurK's Avatar
I'm not sure.
Old Feb 5, 2010 | 11:32 PM
4DGS's Avatar
I didn't know that either.
Check your part numbers then check the corresponding part numbers on intensepower or some random part site. (hoping you got the box for them)
Old Feb 6, 2010 | 01:05 AM
Hi-NRG's Avatar
I had the same problem when I had the shims installed even with the revised version. All I had to do was bent the piece (circle in red in the picture below). I forgot which side it was, but i think it was the driver side.
Old Feb 6, 2010 | 01:41 AM
G35Papa's Avatar
^+1 I've heard of that being an issue before. Also, you need to be sure you use the specialized bolts that came with the kit.
They all use the same arms.....all revised.
Old Feb 6, 2010 | 11:50 AM
tragedycat's Avatar
Not sure what you mean? Back when I was buying front camber arms several years ago SPC made two different ones with two distinct SKU#. This was a result of a lot of G35 coupe owners having the knocking issue.
Somebody even posted a picture of revised vs. unrevised and one arm had more of a bend in it than the other.
Old Feb 6, 2010 | 12:01 PM
herrschaft's Avatar
I've got the revised kit. There's washers that your supposed to install behind the sensors on both front wheels. 2 washers fixed my problem, It may require more if your car is slammed. The washers come with the kit.
Old Feb 6, 2010 | 05:32 PM
TurK's Avatar
Okay we used the same bolts that came with the car....not the kit? Can anyone else agree that your supposed to use the ones that come with the kit?
Old Feb 6, 2010 | 06:20 PM
Hi-NRG's Avatar
This original bolt right here?
You're suppose to, I don't remember see a bolt that comes with the kit for that part.
I followed this entire video right here except I skipped the step @ 5:56 - 6:13. Instead of cutting it, I removed it.
Old Feb 6, 2010 | 08:15 PM
TurK's Avatar
Thanks a lot for that video!
Old Feb 6, 2010 | 08:16 PM
TurK's Avatar
I had a problem with having the left tire wayy to far in compared to the right one....Today i went to get an alignment and they were not able to get the left one in spec...the right one had no problem....
left front -1.84 right front -.47
rears are dead on...
Old Feb 6, 2010 | 08:29 PM
herrschaft's Avatar
I
Are you missing a shim?
Old Feb 6, 2010 | 09:35 PM
Hi-NRG's Avatar
you might also want to double check and see if this piece was place upside down.
Old Feb 6, 2010 | 09:43 PM
Calvin's Avatar
Overglorified Altima
350z's and G35 sedans can install the unrevised arms without issues.
