coolant question
Old Feb 23, 2010 | 07:28 PM
whoisthis's Avatar
coolant question
i changed my coolant like1000 miles ago and i came up with this question now. i drained the coolant from the radiator not the engine block. so im guessing there50% watter in the engine block left but i put 50/50 coolant in. doesnt it mean i ha v more water than coolant? was i suppose to put more coolant than water?
Old Feb 23, 2010 | 08:57 PM
bigc's Avatar
Wings Nation
my bet is you already had 50% coolant / 50% water in your coolant system prior to the drain down so you haven't changed the ratio. had your coolant been serviced prior to the change 1000 miles ago? were you always running the nissan coolant?
Old Feb 23, 2010 | 09:24 PM
whoisthis's Avatar
i changed the coolant 1000 miles ago. i used nissan coolant 50/50.
i had 50/50 in the engine and radiator but when i drained, i re-drained with water until it drained clear water. doesn't it mean that now there's 50% water in the engine block?
and i put 50/50 after draining so i have...100/50 coolant?! lol
Old Feb 24, 2010 | 01:11 AM
partyman66's Avatar
For the reason you just mentioned... unless I'm pulling the block drain plugs before refilling and draining the entire system of the last flush's fluid content.. I usually refill my final fill with something like 70% coolant to 30% water so that it all evens out eventually. You don't really need 50/50 anyways. You can use 60 or 70% water to 30% coolant... especially if you live in a place where it's not too cold.
Old Feb 24, 2010 | 01:33 AM
whoisthis's Avatar
you put 70 coolant n 30 water but its ok to use 70 water n 30 coolant?
what happens if i continuosly put 80 coolant and 20 water?
Old Feb 24, 2010 | 07:23 AM
grovefromnh's Avatar
Use distilled water with your antifreeze
baker2795
Sep 2, 2015 06:00 PM
Blakearold
Aug 27, 2015 12:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
