changing power steering fluid
Old Mar 6, 2010 | 05:11 PM
whoisthis's Avatar
my power steering reservoir read LOW and the color seems to be black..
My car ran 49000 miles and it's 06 g35. Do i need to change the PS??
Also, what fluid is good for DD? amsoil, motul (expensive), redline(expensive)?
thx
Old Mar 6, 2010 | 10:57 PM
smoovarrowhead's Avatar
definately change it especially if you drive it hard often. I ran with Redline fluid I think it was a type of automatic tranny fluid but it can be used for power steering as well there is a DYI from bythebay on Infinitihelp.com to get you on the right track..
Old Mar 6, 2010 | 11:24 PM
gary c's Avatar
Whoisthis, if my fluid was that dark I'd want to drain the whole system. This is more involved than just swapping out the P/S reservoir like I did. Try www.infinitihelp.com there's gotta be a drain plug for the P/S system so you can drain/replace all the fluid with fresh, they can tell you. G/L
Gary
Old Mar 7, 2010 | 12:23 AM
whoisthis's Avatar
idk the original color of the PS fluid but this fluid looked pretty dark to me. i just watched the vid. ia it necessary to hav or replace filter? in the vid he flushed the system with chevron atf. but can i use valvoline dexron3 long life to flush or just use this to refill the reservoir instead of amsoil? thx
Old Mar 7, 2010 | 11:31 AM
whoisthis's Avatar
bump
Old Mar 7, 2010 | 12:59 PM
gary c's Avatar
Considering the cost of a new p/s rack, and it is the seals that fail I'd use the OE fluid. I wouldn't want to disturb those seals with something radically different like synthetic.... my opinion!
Gary
Old Mar 7, 2010 | 03:42 PM
whoisthis's Avatar
i just finished flushing and refilling the PS fluid. Now i'm facing a problem right now
I put all the bolts and clippers back except for 2 clippers. i CANNOT find the place for the 2 clippers...... Everything seems to be tight in place. Should i just leave the 2 clippers out? will they cause a problem?
NemesisGee
Aug 11, 2015 07:10 PM
mann1961
Aug 9, 2015 08:44 AM
