Code P2135 - Dealership says not covered by warranty
Old Mar 8, 2010 | 11:09 AM
phabej_jago's Avatar
So, my 2004 g35 went limp on me on the freeway, couldn't go pass 40 mph. All my VDC, CEL, ABS light came on. I pulled the code and it read P2135 DTC Throttle/Peddle Sensor. So I did some searches on this forum and it looks like this might still be covered under the powertrain warranty. I called the dealership today and they said that the Throttle Body Sensor is electric and is not covered under the powertrain warranty. Should I still take it into the dealership or just attemp to fix it myself? I am unsure if it's the TBS, TPS or the peddle sensor? Anyway on trying to find out which one is the culprit? Any help would be appreciated.
Old Mar 8, 2010 | 11:14 AM
rob40wilson03's Avatar
i have no idea how to fix that.... but my advice would be to call the next closest dealer and see if they tell you the same thing
Old Mar 8, 2010 | 07:10 PM
bythabay's Avatar
Try to reset the throttlebody first, see if that helps.
Old Mar 8, 2010 | 08:42 PM
Thanks, I'll try that and maybe try cleaning it first to see if that solves the issue.
Hasanbaloch
Feb 29, 2024 08:45 PM
ara777
Aug 15, 2018 04:11 AM
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
