window tints
Old Mar 9, 2010 | 12:11 AM
the evil i's Avatar
window tints
im planning on getting window tints sometime in the next week or so. but i thought of something that could mess them up
when you open and close the door, the window automatically comes up and down a little bit, and since ur not supposed to open or close your window for a few days, wouldnt that mess up the tints and make them peel?
Old Mar 9, 2010 | 12:25 AM
rob40wilson03's Avatar
when i got mine done, i just tried to minimize opening and closing the doors the first day or so and they were fine
im pretty sure that the edges cure first, so by the time you get it home it will probably already be ok
Old Mar 9, 2010 | 12:38 AM
herrschaft's Avatar
Didn't have any issues with mine.
Old Mar 9, 2010 | 12:44 AM
jknuttila's Avatar
i had a problem with this, one week after i got them tinted it started to peel off the passenger window.. i took it back to the place and there was no refund on peeling i got it redone and didnt open the door for about 5 days and then cracked the window about an inch and left it like that for another week. the window is good now and its been about a 2 months
Old Mar 9, 2010 | 12:56 AM
herrschaft's Avatar
The first few days after I got the tint, I let the car run for about 30 minutes every night with the heat blasting. I'm sure this helped a little.
Old Mar 9, 2010 | 01:17 AM
Night Ryda's Avatar
if your tints mess up just because of that little drop, then you know its a **** poor tint job.
Old Mar 9, 2010 | 01:19 AM
Silencer_0's Avatar
I've had my front windows tinted twice by this local stereo shop (twice because I had to have it removed for a ticket), and never had a problem with it peeling. And I've opened and closed my windows like normal the day after getting them tinted.
Old Mar 9, 2010 | 01:26 AM
gary c's Avatar
No issue with my tint, ever.
Gary
Old Mar 9, 2010 | 01:29 AM
Xet's Avatar
Xet
shouldn't have a problem, if you do it's a crap job.
Old Mar 9, 2010 | 02:32 AM
realmothafckinG's Avatar
i accidentally rolled the window on the way home from the tint place before reading the instructions thing they gave me. probably rolled it up and down at least twice, but i haven't had no problems. besides, the place i went to give a 100% money back warranty against cracking or bubbling
Old Mar 9, 2010 | 02:36 AM
Deepdiver's Avatar
it doesn't matter if you have a good job, bad job, and no you don't need to crawl out the trunk. What you need to do is remove the screw that is underneath the dome light/window actuator that is located on the door jamb. Once removed, the window will no longer roll down upon opening the door.
Old Mar 9, 2010 | 03:06 AM
Ig35's Avatar
^ thats what the installer did when i got my windows tinted a few months ago.
Old Mar 9, 2010 | 03:48 AM
elayman's Avatar
mine were fine and have a lifetime warranty against bubbling, peeling, and color changing.. go to a better shop
Old Mar 9, 2010 | 05:36 AM
Tabris's Avatar
What kind of tint shop wouldn't fix peeling (especially a week later)? What else does the tint have to do besides staying on the window? That's their job, that's what you paid them to do.. I'd find another tint shop (one that gives warranty on the work you pay for).
Old Mar 9, 2010 | 06:36 AM
headshot's Avatar
Its all in what product they are using and how well the install is. The norm is to wait a couple of days but if that sun is beating on it, you will be ok if the install is good.
