Washed car, water got into driver side footwell
Old Mar 14, 2010 | 08:48 PM
paymon's Avatar
I recently had a sound system installed in my car and I am guessing the line that goes from the battery to the amp required the installer to make some sort of puncture in the firewall? After I washed my car there was some water on my drivers side floor mat, probably 2" in diameter. What should I do?
Old Mar 14, 2010 | 08:59 PM
Calvin's Avatar
Overglorified Altima
Yes, I had this same problem. Installers drilled through my firewall and did not seal it properly. Not my driver side floor gets wet when I wash it or it rains.
Find a grommet at your hardware store that will seal it or silicone it for a more permanent fix.
Old Mar 14, 2010 | 09:04 PM
paymon's Avatar
Is siliconing it something I could do myself? The most I have ever done mechanically is change the sparkplugs on my G, lol. I assume the silicone just comes in a tube?
Old Mar 14, 2010 | 09:06 PM
Calvin's Avatar
Yep. But I'd recommend trying to find a grommet first. If you can't, then use silicone.
Old Mar 14, 2010 | 09:10 PM
paymon's Avatar
Thanks for the help. I guess I will be paying a visit to Autozone soon.
Calvin's Avatar
I'd try Home Depot, Lowes, Ace, etc., too.
Old Mar 14, 2010 | 09:11 PM
paymon's Avatar
Will a grommet wrap around the wire and cover the hole? Or do I have to remove the wire, insert the grommet, then run the wire through the grommet again?
mconklin's Avatar
man...I would take it back to the installer, and then never go back cause they suck. If you want to do it yourself you will need to follow the wire from the battery to find where they drilled into the firewall, you can buy a rubber bushing that will slide over the wire and seal the hole. good luck
this is what you need. http://www.crutchfield.com/g_183750/...s.html?tp=1283 you can get it at any car stereo shop.
Old Mar 14, 2010 | 09:13 PM
mconklin's Avatar
you will have to disconnect the wire from the battery
Old Mar 14, 2010 | 10:01 PM
G35Papa's Avatar
I'm betting they just peeled back the large grommet where the main harness comes through the firewall and just pushed the wires through the side of it. That's what happened to me. I winded up taking off the cover under the windshield wiper arm and puncturing the grommet, fished my wires through then used silicone to seal up around the wires/puncture in the grommet.
Old Mar 21, 2010 | 02:20 AM
Infiniti_Energy's Avatar
hahahh that sucks, black is the worst color to wash ever
Old Mar 21, 2010 | 04:25 AM
Blue Dream's Avatar
I drove ttrank's car solo
Can you please contribute something worthwhile? You have resurrected numerous threads with a bunch of BS posts.
Old Mar 21, 2010 | 04:32 AM
j 4 lD's Avatar
lolol +1
Old Mar 21, 2010 | 05:09 AM
thescreensavers's Avatar
Mr.202?
I think its infinitisport or w/e his name was lol that made ton of bs posts.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
