PLZ HELP: IS ENGINE HEAT NORMAL?
Old Sep 12, 2004 | 02:50 PM
GCoupe35's Avatar
As i was coming home last night my cousin pointed out that there is Hot ait coming out from the A/C vents. I did not turn my A/C on my windows were down but as i was driving fast the hot ait was coming in from the Vents. Then i got home poped the hood and there is hot air coming form the engine. No smoke or anything like that just feel the hot air. Also, there was hot air coming from the exhuast.
I was revin high and going pretty fast. Maybe this could cause the hot air? Any Advise?
Old Sep 12, 2004 | 03:07 PM
Q45tech's Avatar
Re: PLZ HELP: IS ENGINE HEAT NORMAL?
Burning a gallon of gasoline in an engine creates ~~120,000 BTU of heat only 25-28% is converted into moving the car. The rest is radiated out the radiator, radiated from the engine block or sent out the exhaust pipe.
Like having 7 electric space heaters under the hood.
In Summer 160-180F under the hood is normal pretty much what the coolant temperature is 180-200F.
Old Sep 12, 2004 | 05:13 PM
EZZ's Avatar
EZZ
Totally normal. The G doesn't have a very efficient venting system. Seems that hot air is the norm for everybody.
04 Coupe Auto/DG/Prem/Nav/Perf
Old Sep 12, 2004 | 08:54 PM
Q45tech's Avatar
"but usually the climate control system (even when it's off) does something to cool the air off a bit so you don't bake."
If the outside air is at or below 60F the inside vent air might be 68F or higher. Much higher ambient and you have to open windows or use AC............each car varies a few degrees as to the need for AC point.
Jiggerjuice
Oct 5, 2015 02:33 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
Phenomenon9
Aug 9, 2015 01:34 AM
ghost_g35
Aug 7, 2015 10:31 AM
