Seeking advice on AFTER MARKET clutch!
Old Mar 27, 2010 | 06:42 PM
spacecitygroove's Avatar
My clutch is slipping, and Im ready to replace it.
My mechanic quoted me 250 for labor to replace it.. does this sound fair??
I have to buy the parts myself tho.
Im thinking about ordering an Exedy clutch kit from partsgeek.com
The kit doesnt include the flywheel, and the price is 260.
I would have to purchase a new flywheel seperately.
I should be spending around 600-700 all together for the replacement in total.
Does this sound reasonable to you guys?
Im a car newb, and I dont want to get ripped off....
Any advice would be greatly appreciated..
If you know of a good, cheap after market clutch kit, please chim in
Thanks
2003, g35 6mt with 85k miles
Old Mar 27, 2010 | 06:45 PM
TIAN's Avatar
Hold The Line
Jim Wolf Technology
Old Mar 27, 2010 | 07:05 PM
Old Mar 27, 2010 | 07:12 PM
TIAN's Avatar
Hold The Line
.........?250 for labor is very reasonable........SEARCH.
Old Mar 27, 2010 | 10:17 PM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
exedy, 250 is really reasonable, make sure you replace everything, might as well while your in there.
Old Mar 27, 2010 | 10:47 PM
Deepdiver's Avatar
$250 is an excellent price for labor. At 85K miles, you really should replace the flywheel while you're in there.
Old Mar 27, 2010 | 11:01 PM
UrangeAve's Avatar
I just paid 340 for labor but I got my ACT clutch/flywheel combo for only $450 so I cant complain. Happy so far.
Old Mar 27, 2010 | 11:07 PM
Deepdiver's Avatar
^which fly did you get? Streetlite?
Old Mar 28, 2010 | 12:16 AM
jsdrn's Avatar
exedy
Old Mar 28, 2010 | 12:23 AM
UrangeAve's Avatar
I got the Pro Lite........a Litte noisy when it warms up but really not that bad. Performance makes up for the noise. Feels like the car is launching rather them just pulling.
Old Mar 28, 2010 | 03:48 AM
so i dont think my clutch is slipping after all..
I did the tranny test where you put the car is a higher gear while driving slow to see if the rpms jump.. but they didnt....
So whats wrong with my G?
Its slugggish...
It doesnt pick up speed like a normal G. Theres no power when i floor it.. it just gradually increases in speed..NOT normal.
Could sparkplugs be the culprit?
Ive used the gas fuel injector mix.
Ive changed the air filter..
Whats the deal here....
Old Mar 28, 2010 | 04:50 AM
Revo's Avatar
Well...it'd be nice...if you didn't...put so many...periods...between your phrases...cause it makes it a pain...in the ***...to read...periods...were made...to end sentences...and spaces...were made to...space words...grammer is your friend... ... .... .... ... .... ......................... .... ...... ...
That being said, was the car at a decent RPM in 6th gear? You can't expect your car to generate enough grunt to make the clutch slip at like 1500RPM. If you do the 6th gear test, you'll have to be doing like 80mph to get your motor up to about 3000RPM. I'd use 5th gear, it'll just as likely slip in 5th and you'll be able to get the RPM's up into the power band to really test the clutch.
Old Mar 28, 2010 | 10:55 AM
carsontl's Avatar
Side question here, how exactly do you know when your clutch is 'slipping'? I've never experienced (atleast I don't think I have) this issue so I don't know how it feels.
Old Mar 28, 2010 | 12:14 PM
MyaLover's Avatar
Generally you'd experience this when there is extra stress on the car (like going up a hill or WOT).
It will usually happen in the higher gears and you'll see your RPMs raise pretty quickly, but your car will not be picking up speed at the same rate.
Old Mar 28, 2010 | 04:22 PM
could oil in my spark plugs cause this sluggishness?
When I was changingm my oil, i noticed that there was very little oil coming out as i was draining it....
