how come i don't have to push the clutch in to start my G
Old Apr 13, 2010 | 10:11 PM
vp-g's Avatar
every manual car i have driven i had to press the clutch in to start. why not the G is that normal?
Old Apr 13, 2010 | 10:14 PM
Focusedintntion's Avatar
Sounds like the clutch position sensor is stuck or bad....
Old Apr 13, 2010 | 10:19 PM
NachoCheese's Avatar
Or bypassed. I had an 02 GTI that I could start without pushing the clutch in. I think the old owner bypassed it.
Old Apr 13, 2010 | 10:26 PM
Beebo's Avatar
yeah it can be bypassed
Old Apr 13, 2010 | 10:43 PM
vp-g's Avatar
^ how?
Old Apr 13, 2010 | 10:53 PM
A piece of tape can do it on some cars lol...have you looked down under there?
Old Apr 14, 2010 | 12:14 AM
loki05's Avatar
on my brother's tc I installed a remote start button on the car and it required bypassing the clutch. maybe something of this nature was done previously
Old Apr 14, 2010 | 12:33 AM
jookyshank's Avatar
I haz hugz to givez
^ +1
When I installed my remote start we just bypassed the sensor simple and that's probably what's up with yours
Old Apr 14, 2010 | 01:05 AM
gary c's Avatar
You should always push the clutch in when you're starting the G anyway! One of the first lessons my Dad taught me when I was learning to drive along with get you foot off the clutch pedal once it's in gear. That's why I've never replaced a clutch....thanks Dad!
Gary
Old Apr 14, 2010 | 04:51 AM
aosmdavid's Avatar
yeah, the previous owner could have by passed the clutch for a remote start. It's usually a little harder than a piece of tape though =P It shouldn't be bad for you car, and like gary c says, you should always push the clutch down when you start the car anyways.
Old Apr 14, 2010 | 07:32 AM
vp-g's Avatar
so where is this by pass switch that you guys speek of? and how do I remove it? if that is the case..
Old Apr 14, 2010 | 08:38 AM
Why do you wanna remove it? I don't think it really matters either way.
Old Apr 14, 2010 | 08:45 AM
vp-g's Avatar
I just want it normal like it should be.
Old Apr 14, 2010 | 11:39 AM
vinco's Avatar
I actually want to bypass mine, because the clutch is so stiff. My concern is that as stiff as the clutch is, it could cause premature wear on the crankshaft thrust bearings at startup, before the oil pressure comes up. I haven't looked at the pedal or switch yet, but is there another way to bypass besides tape?
Old Apr 14, 2010 | 11:51 AM
GAU-8's Avatar
Does it start in gear or only in neutral? If it only starts in neutral, there's a bypass switch. If it starts in gear you have bigger problems because it should buck like a Bronco and possibly run in to something if in gear and starting.
