braking light", "slip" and the "traction control" light are on
Old Apr 24, 2010 | 11:56 AM
lazychina123's Avatar
2004 g35 sedan with mannual transmission, one day i drive the car in a highway and it was rainning when i hit the brake quite hard, then the "braking light", "slip" and the "traction control" light are on at the same time. but after i drive for 20 minutes they are off, this happend 2 times already, does anyone know what happen? does this indicate that i have to change the brake pad and add braking fluid( but the braking pad and the fluid should indicated only by the "braking light, right?)? Thanks for help
Old Apr 24, 2010 | 12:09 PM
chuk1005's Avatar
From what I understand it means you need to change your brake pads. As far as the braking light being the warning signal for replacing brake pads I dont think this is the case for Infiniti's.
Old Apr 24, 2010 | 03:05 PM
Iamnotkento's Avatar
Its normal if the lights are off now.
Old Apr 24, 2010 | 05:18 PM
superchargedg's Avatar
Sounds like you need to check the level of your brake fluid.......i bet its low.
Old Apr 25, 2010 | 01:04 AM
TheTick's Avatar
Change your pads or add a bit of brake fluid. Worked for me.
Old Apr 25, 2010 | 11:25 AM
Sammy23's Avatar
could be your wheel bearings....do u hear a vibrating sound when your turning kinda fast?
Old Apr 25, 2010 | 11:31 AM
vipers's Avatar
He is 100% correct. As stupid as this sounds, it works. I had this problem for a few months and as soon as I changed my pads, the codes went away.
Old Apr 26, 2010 | 12:59 PM
G35 Drummer's Avatar
i love this site! i have the same problem but now i know what to do.
Old Apr 26, 2010 | 01:43 PM
damdlux's Avatar
Check your brake fluid. I had the same problem once, added some brake fluid and the lights went off.
Old Apr 26, 2010 | 04:49 PM
dr.g35's Avatar
That was my case.
11bEMT
May 27, 2022 03:13 PM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
mike730
Jan 12, 2018 04:25 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
Lsantana757
Jul 20, 2015 09:08 AM
