Please help identify these two parts (Pics) inside.
wrong.
1st picture is the radius or "trailing arm" The toe arm is the spring bucket itself. Altough the when buying an adjustable radius or trailing arm you can adjust a small amount of toe, it is not the actual toe arm.
2nd picture is the lateral or camber arm as you stated.
Ok so for the first pic I showed you guys which one is the one I have to buy from the link above and also which is most recommended if I was going to go in the future for an aggressive streched look
