Please help identify these two parts (Pics) inside.
Old Apr 27, 2010 | 05:07 PM
alex_b's Avatar
Exclamation Please help identify these two parts (Pics) inside.
This is the right rear wheel of the car. My dad lost control and bent these parts.
These two are the same part just diffrent angels.
This is the second part which is believe are the camber arms.
Old Apr 27, 2010 | 05:31 PM
G35fromPA's Avatar
I believe the first one is the the radius rod and the second is the front lower link, though I'm not 100% sure as I'm referencing the coupe FSM. Maybe best to post this in the Brakes and Suspension subforum to see if someone knows for sure.
Old Apr 27, 2010 | 06:51 PM
gck's Avatar
gck
the first is the camber arm and the other is the sway bar
whats wrong?
Old Apr 27, 2010 | 06:55 PM
Swivel's Avatar
Moderator
None of those is the sway bar. Maybe this will help:
Old Apr 27, 2010 | 07:00 PM
istan's Avatar
Rear Traction Arm and Camber Arm.
http://my350z.com/forum/suspension/4...-sports-2.html
Old Apr 27, 2010 | 10:49 PM
alex_b's Avatar
^^^Thanks so much. I was looking at that vendor earlier but wasnt sure exactly which to order? Which camber arm should i go for ichiba or circuit? im going for the aggressive look sometime in the future?
Old Apr 28, 2010 | 05:03 AM
Blue Dream's Avatar
I drove ttrank's car solo
lmao at some of the responses here. Sway bar.......really?????????????????
People, when someone asks for help please don't just pull **** out of your azz. It sucks to be looking for a solution to a problem only to be guided in the wrong direction by someone who "thinks" they know what they are talking about. If you're not sure what you are about to post is correct, keep it to yourself!!!!!!!
Old Apr 28, 2010 | 06:32 AM
Tabris's Avatar
Wouldn't this be the second G that has had this kind of damage lately? The first from a friend, and now this owners dad?
Lesson: Let no one drive your car
Old Apr 28, 2010 | 09:33 AM
walshtj's Avatar
Yeah I am always weary whenever I let somebody else drive my car. I know that the second one is the chamber arm but not sure about the first. Good luck.
Old Apr 28, 2010 | 09:39 AM
G35fromPA's Avatar
The diagram you posted is the front suspension. The parts the OP was asking about are in the rear suspension.
Old Apr 28, 2010 | 07:00 PM
culi's Avatar
Looks like lateral arm to me.
http://www.infinitipartsusa.com/part...layCatalogid=0
Attached Thumbnails Please help identify these two parts (Pics) inside.-1.gif   Please help identify these two parts (Pics) inside.-capture.jpg
Old Apr 29, 2010 | 12:11 PM
SleekStyle's Avatar
1 pic toe arm
2nd pic lateral arm / camber arm
Old Apr 29, 2010 | 12:18 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by sleek6mt
1 pic toe arm
wrong.
1st picture is the radius or "trailing arm" The toe arm is the spring bucket itself. Altough the when buying an adjustable radius or trailing arm you can adjust a small amount of toe, it is not the actual toe arm.
2nd picture is the lateral or camber arm as you stated.
Old Apr 29, 2010 | 01:04 PM
Calvin's Avatar
Overglorified Altima
^^^youre alive!
Old Apr 29, 2010 | 01:06 PM
Originally Posted by calvin
^^^youre alive!
lol!
