Rattle from rear window?
Old Apr 30, 2010 | 11:26 AM
NeoValentine's Avatar
Hey guys it's been awhile since I posted on here, was hoping to get some help. My car has developted this annoying rattle coming from the passanger side rear window or it's surrounding plastics. I've found that while driving if I push on the plastic around the window the sound goes away, as soon as I let go it comes back. I was wondering in anyone else has fixed this issue, and if so what did you use. Is there a picture walkthrough with how to remove this piece so I can look around at securing it better?
Thanks,
Ron
Old Apr 30, 2010 | 12:05 PM
icefire's Avatar
yeah i have the same issue and would be interested in a fix as well
I was going to just take it all off and put some foam padding or dynomat type material under it and re attach but was reluctant.
Old May 1, 2010 | 01:15 PM
856-ZIC's Avatar
I got the same issue. Really appreciate it if someone show us how to fix that.
Old May 1, 2010 | 03:18 PM
jutn35's Avatar
G35 Coupe
sure its not the seatbelt hahaa, but i have the same problem on my driver side
Old May 3, 2010 | 01:06 PM
Yes I double checked the Seatbelt this weekend to see if that's where it was coming from. It's behind the rear window plastics.
Old May 3, 2010 | 03:02 PM
jardoeli's Avatar
So do I !
Old May 3, 2010 | 03:18 PM
JPilla19's Avatar
Here's a .pdf of some squeak and rattle repairs for a 2003 coupe. I pulled it off of http://infinitihelp.com/. Sounds like the defogger condenser.
File Type: pdf
Old May 6, 2010 | 08:59 AM
noxowner99's Avatar
Thumbs up
BTW thanks for the info...very helpfull....
Old May 6, 2010 | 02:25 PM
Thanks for the PDF, do you also have the PDF on how to remove the Window C-pillar?
Ron
Old May 9, 2010 | 05:23 AM
TigerKneeCrush's Avatar
i think it's just bass from the Bose
Old May 10, 2010 | 11:18 AM
It's not cause I can hear it even when the radio is off and I'm driving. Every vibration in the road causes it.
Old May 11, 2010 | 01:36 AM
hmm
Old May 11, 2010 | 09:40 AM
JPilla19's Avatar
Here it is. Again, I pulled this from the website http://www.infinitihelp.com/, this is for a 2004 coupe.
http://x.infinitihelp.com/forum/loca...s.php?catid=20
Follow this link to the 2004 Exterior/Interior service manual. You will have to register a username for the site, but it's well worth it. There's also a download limit of like 2 files per day, but you can get everything you need spread out over like a week. I have everything downloaded for a 2003 coupe that I thought I could use. Check out the service bulletins too.
I tried to upload the .pdf just like last time, but it won't let me. Hope this helps.
Old May 11, 2010 | 10:19 AM
JPilla19's Avatar
I couldn't find the service manuals for how to remove the seat belt bolts or the rear seat cushion, but to remove this rear pillar garnish piece seems to be intensive.
Old May 11, 2010 | 11:24 AM
Yeah was looking for some guidelines instead of going at it blind. Will keep looking for a good walkthrough or service guide.
