Heated seat light not working
Old May 3, 2010 | 11:19 AM
racerxvi's Avatar
The background illumination on the driver's side heated seat switch is not working anymore. My extended warranty does not cover the repair for this. Does anyone know if this is something I can do myself (I have zero experience doing this)? If not, how much would this typically cost?
Old May 3, 2010 | 12:26 PM
iceguju's Avatar
I have the same issue. I don't know what the bulb type is for that switch. Its easy to get to though. All you do is take the shifter **** out and pull the whole unit up from where the cupholders are. To take off the shifter **** off, pull the piece all the way at the bottom down. then you will see a pin. Remove the pin and the shifter will be able to pull up easily. Just don't lose the pin! I am sure you can ask the dealership for the bulb and just do it yourself.
Old Oct 20, 2010 | 04:12 PM
V's G's Avatar
I have the same issue and would like to fix it since it bugs me. Does anyone have a DIY for this?
Old Oct 20, 2010 | 07:10 PM
the evil i's Avatar
never got around to doing it myself, but heres the diy i found a long time ago
https://g35driver.com/forums/interio...-mod-pics.html
Old Oct 21, 2010 | 12:59 PM
V's G's Avatar
thanks
Old Oct 21, 2010 | 02:41 PM
spoolinupblue's Avatar
thanks for the find....1 of mine is out also.
Old Oct 22, 2010 | 03:44 PM
cpufreak3's Avatar
How do you take the switch out... my driver's side went out a few days ago
arora_g35
Apr 16, 2026 02:52 PM
Rokafor
Jul 29, 2015 11:50 PM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
