05 G35 Coupe shakes at 70mph
Old May 7, 2010 | 04:49 PM
bjquinnIUmed's Avatar
you don't need spacers for the problem that you described. Spacers change the offset of your wheels and have no bearing on their balance while on the vehicle. You likely need one of two things done:
1. hubcentric rings for all 4 wheels. Go to where you purchased the wheels from or any wheel/tire store and they'll be able to get you a set specific for your car and the wheels you have.
2. your wheels may not have been balanced properly OR they may have thrown a weight following proper balancing. Have them rebalanced to ensure it's not the problem causing your vibration, but I'd hold off on this until you get your hubcentric rings installed.
If it was any issue related to the brake rotors, you'd feel the vibration while braking at speed, not cruising.
Old May 7, 2010 | 07:13 PM
Night Ryda's Avatar
Wheels aren't balanced.
Old May 8, 2010 | 07:58 PM
PlayB0i152's Avatar
cool thnx.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ghost_g35
Aug 7, 2015 10:31 AM
laksjd84
Steering & Suspension
Aug 3, 2015 02:44 PM
laksjd84
Jul 24, 2015 05:12 PM
