Weird whistling noise
Old May 9, 2010 | 03:52 PM
izzueeek's Avatar
Hi, I have a 2005 G35 Coupe M6.
Couple days ago I heard this weird whistling noise whenever I change gears and when i let go of the throttle.
Like when I am in second gear around 2000-2500RPM whenever I let go of the throttle the sound comes in. But when I rev the car at idle you don't hear anything.
Anyone have this problem before?
Old May 10, 2010 | 02:00 AM
scottfedm's Avatar
I think I know what you are talking about. Sounds like its coming from one of the front wheels. I'm still trying to track it down so if you find out before i do let me know.
Old May 10, 2010 | 02:18 AM
jonesmeister11's Avatar
i thought it was my intake
Old May 10, 2010 | 03:26 AM
Footballmania32's Avatar
Sounds like you have a super ultra rare Infiniti TT kit
Haha, jk. Wish I could help though!
-Sean
Old May 10, 2010 | 04:01 AM
herrschaft's Avatar
Hey Ronnie, is that you?
Could it be a vacuum line?
Old May 10, 2010 | 09:49 AM
KSWAY's Avatar
Did you install your Supercharger backwards?
Old May 10, 2010 | 08:11 PM
izzueeek's Avatar
Nope im not Ronnie.
Ok, yesterday when I started the car, I heard this new sound which is coming from the engine when the car is at idle. This sound is different than the whistling/rattling sound and it sounds more scary, sounds like the car is going to break down.
I talked to my buddy, he said it might be the transmission =[
Old May 10, 2010 | 08:14 PM
K-BizzG35's Avatar
Nope im not Ronnie.
Does it go away after the car warms up?
Old May 10, 2010 | 08:23 PM
NachoCheese's Avatar
This started happening after I put on my pop charger. It's probably your intake and how it sucks in air at certain RPMs. My pop charger does that at 3k RPMs
Old May 10, 2010 | 08:29 PM
05_Silver_G35's Avatar
check if the air intake filter has loose screws
Old May 11, 2010 | 06:29 PM
1trueG's Avatar
I've had the same thing for the longest time...No one has been able to come up with an answer or fix. Most likely, im guessing its either some kind of leak or transmission issue. Sounds like a whistling/whining noise when you accelerate after changing gears right?
Old May 11, 2010 | 10:46 PM
scottfedm's Avatar
It only happens when the car is cool. Its not the air filter. I dont think its the trans, nothing changes in the way the car rides or shifts, not to mention there are no leaks. But yeah 1trueg knows exactly when it happens and what it sounds like. If it were the trans i would think it would change the way the car shifts or rides, especially when i shift. I'm half way thinking it may have something to do with the belts or pulleys. Im not sure yet tho.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
