Need your help.. =(
Old May 9, 2010 | 07:13 PM
Ogz007's Avatar
Need your help.. =(
Hello guys,
I need your help.
I have a very scary problem at the moment with my V35 2003, last night my interior lighst werent working..pretty standard, looked in the fuse box and saw a blown up fuse.
I have changed it with the ones that are place on the blank charts assuming it’s a spare one?. (fuse diagram behind the cover) so everythign went well, I then relaised that my signal lights are working outside but I cannot see this on my dash flashing…=(
I since then have taken the fuse out and returned it to where I got it. But no result...
Before this (another problem), probably about 2 months ago my door step lights have stopped working on me when I tried replacing it with a LED bulb.
I finally got on to it with a friend, grabbed a digital tester and tested the thing. The bulb is fine, the holder or housing (the copper that holds the bulbs) is fine and the main connector (that you can clip and unclip) that is giving power is ok. So I was clueless….
#2, both of my windows is now bummed out too, when I open the door it will go down as usual but then it would go up and down again. I notice that the interior lights (in open door mode) are in sequence with the window when it wants to play up. Goes on and off.
The sensor bit (door) seems like its causing me a lot of grief. Even when I unscrew it, its reacting already (as I can hear frictions) so looks like its grounded with the entire thing. When I replaced the fuse to get the interior lights workng again my window does not go down or no longer plays up as it normally would when it is opened so it died out completely…. The interior lights (in open door mode) does not turn on also, unless I manually turn it on.
Sorry to be a little confusing.. I guess my main problems are the signal lights on my dash cluster and I guess what do I do with this stressful sensor…
Thank you guys in advance.
Old May 10, 2010 | 08:53 AM
Ogz007's Avatar
anyone? =/
BigVicG35
Nov 20, 2008 04:42 PM
amoreno35
Jun 26, 2008 02:20 AM
emorehs
May 8, 2008 06:46 PM
zaid918
Mar 19, 2003 10:02 PM
