06 G35 Headlights fuse
I looked all over and so far I found out that there are a total of 3 fuse boxes I think. I found the one infront of the battery and the one next to the brake pedals drivers side.
So is there one more behind the battery that has the Headlight fuses? I couldn't find the fuses anywhere else.
Any tips on how to access that fuse box? When I look at it from under the hood it would seem I would need to remove the entire battery...... Thanks
You need to remove the cover that is directly above the battery. Then u may access the third fuse box. You do not need to pull the battery. The cover is held in place using the simple key clips.
Oh alright thanks. I was able to replace my headlight fuse but it blew right when I tried to turn my headlight on.....bulbs replaced and everything so I guess theres a short somwhere. Guess Ill be taking my car to the dealer...
sounds good. I think it could be a loose bulb.....the guy that installed my new bulb looked like he had no idea what he was doing. So if its not do I follow the bulb wires around to make sure they arent touching anything else?
Im new at this but im learning quite a bit on my car, need to start fixing it on my own.
Ok so I went to the dealer and they said they want 800$ to replace the entire HID control unit. My friend told me I shouldn't do it. So I didn't. I will look for the parts and find my own mechanic to help me out. Any tips on were to start looking though? ebay maybe lol.
bTanz
Oct 15, 2015 02:31 PM
laksjd84
Jul 24, 2015 05:12 PM
