has your FRAM oil filter FAILED?
Old May 24, 2010 | 03:21 PM
jutn35's Avatar
G35 Coupe
K&N always
Old May 24, 2010 | 06:11 PM
slim17265's Avatar
Originally Posted by SwivelHips
There are apparently good Nissan filters and poor ones. Filched from a Driver thread filched from a Maxima thread:
Nissan OEM 15208-9E000 (metal cap)
Nissan OEM 15208-65F00 (cardboard...AVOID)
the one I took out is an 65 F0C and if the car was left sit for 2 days it would knock startin up...just replaced with a Tech..so far so good
Old May 25, 2010 | 11:51 AM
LightsOut's Avatar
SIETESG
everyone knows frams sux. Wix all the way for me.
Old May 31, 2010 | 06:08 AM
bound4VIP's Avatar
I have worked on cars since i was a kid, so im no noob by any means.
I have never had a problem with Fram oil filters....till now. I changed my oil and oil filter. Used fram Tough gaurd, never again. I changed my oil and oil filter, everything was nice and tight. Started my car and oil went every where, I mean every where. The passenger side of the motor is covered in oil! Not to mention I get to clean the concrete in the garage. So i have a fun day ahead of me. Any ideas on cleaner for the concrete.
Old May 31, 2010 | 07:36 AM
thescreensavers's Avatar
Mr.202?
^Dawn is pretty good, but if its soaked in idk :O
Old May 31, 2010 | 08:40 AM
Project's Avatar
I would try some absorbent compound first to draw the oil up. Then dawn on top. Usually it will cut the oil.
Old May 31, 2010 | 01:09 PM
SVTCOBRA's Avatar
Use some cheap kitty litter. I would use an old pair of shoes and grind it in. Let it sit for a while so it can absord. I dropped several quarts of oil years ago changing it in my 88 bronco II.....I left the old gasket on the block...two gaskets make a mess!!!!
Old May 31, 2010 | 03:46 PM
blaccG35's Avatar
so if i were to get a K&N or Mobil1 Filter would i need to change it every oil change and if i were to use a OEM filter?
Old May 31, 2010 | 04:11 PM
Mr.202?
Same with OEM filter. I change my filters every time I change my oil. Its so easy why not?
Old May 31, 2010 | 06:20 PM
Lee R's Avatar
I just searched "bad Fram oil filter" on Google images.....ouch.
seagrasser
May 3, 2022 09:43 AM
NailBomb
Oct 28, 2015 07:53 AM
yosip1115
16
Sep 28, 2015 04:14 PM
sullivan72
Sep 22, 2015 11:39 PM
DRG35R
Sep 16, 2015 05:33 AM
