Horrible road noise with 19" OEM rays?
Old May 25, 2010 | 09:08 PM
sillyoldtayo's Avatar
yah those factory tires were terrible! I had the worst road noise especially when slowing down. got some Yoko's and instantly quieted down
Old May 25, 2010 | 11:17 PM
tEh d0ct0r's Avatar
Originally Posted by TechCase
Although I can't say for certain since my experience did not involve the steering wheel vibrating when you come to a stop, I don't know if it's balancing or worn tires. When I first bought my car, the car had about 6/32+ all around, but the noise was already there. Then I switched to winter set, and the noise was gone, and when I switched to my summer set, the noise was there still although I got the set balanced/mounted/aligned at the stealership. Unfortunately, I was told that there's no way to "fix" feathering once it occurs, so you either live with the noise until the tread wears out, or replace the tires.
How much did they charge you for the mount/balance/alignment?
Old May 25, 2010 | 11:41 PM
stbeeman's Avatar
Had the same issue on factory 18s when I bought my G35 - same tires, badly feathered. Bought a set of Michelin Pilot and 4-wheel alignment and it's like a brand new car babe.
Old May 26, 2010 | 12:05 AM
2K6G35c's Avatar
Mounting, balancing and alignment on a set of 19's will set you back about $200. I got mine installed and balanced for $100 at Discount tire because some bozo that fixed a tire before quoted me $20 per tire.
Old May 26, 2010 | 12:30 AM
gary c's Avatar
There's nothing more important than balance and alignment to make your tires live along with how nice it handles when everything's right. Those Stones are likely shot, are the inside of your fronts worn? That's where we get the famous tire "Roar" from 30 MPH down. No matter how loud you turn up your tunes it's there....
Gary
Old May 26, 2010 | 02:06 AM
TechCase's Avatar
Mount/Balance was 140 ($35/wheel - although the tires were already mounted on the wheels) and 150 for alignment..... Don't think I'll go back there again...
Old May 26, 2010 | 02:08 AM
BonBG35's Avatar
lol my stealership wanted 200 for an alignment.
Old May 26, 2010 | 02:26 AM
TechCase's Avatar
^lol you got me beat. But then again, you are in NYC
Old May 26, 2010 | 01:25 PM
cpufreak3's Avatar
So I got the wheels balanced yesterday... no change!
Like Gary said, it's under 30 MPH, and on my 18s, I could turn the music up. Doesn't work here.
Front treads look good, with even wear.
The rears are a little uneven, but honestly, the noise has to be from the front.
That's actually what I'm experiencing. During braking it's much worse...
Old May 26, 2010 | 03:50 PM
TechCase's Avatar
^sounds more and more like tire feathering/cupping... can you see small cracks all over the tire when you're up close? try running your hand across the tire to see if its smooth...
Also, from maintenance perspective, always maintain tire pressure to spec... I learned at the recent dyno meet that the center of my rear tires are nearly bald... while the sides had decent tread left... <-- result of me being lazy and increasing pressure about 3psi over spec every time I fill so that I wouldn't have to care about checking pressure as much.
Old May 26, 2010 | 03:51 PM
changeover's Avatar
I have this exact problem with my car now...I have brand new (4-5 thousand miles on them) Nankang sport tires. Got an alignment right when I got the car and it was fine then a little afterwards the noise.....its all right when going over 50, bad under that and the worst when I brake. I havent had them balanced and I dont remember if they are directional or not. Do you think balancing them would help get rid of the noise or is there something wrong with my car?? No thread hijack haha.
Old May 26, 2010 | 04:22 PM
OGKushRob's Avatar
damn...fail G owners haha i too am having this problem from either my front tires or my brake pads when coming to a stop from 25mph and under. i have toyo tires that were on the car when i bought it.
Old May 26, 2010 | 05:10 PM
BonBG35's Avatar
the vibrations and whirring noises are still there? wtfffffffff
im sure you already checked the psi right?
Old May 26, 2010 | 05:18 PM
cpufreak3's Avatar
I did check the pressure, but what's the proper way to fill it up?
The tires have a max pressure of 40, so I filled to 35?
Pics of tires will be up soon.
EDIT: So the tires are feathered on the inside. Guess that's the problem...
Old May 26, 2010 | 08:38 PM
  #30
TechCase's Avatar
that sucks, but yeah I don't think its uncommon with G35 coupes. But you should still do all those precautionary things members mentioned here as far as balancing/alignment/pressure stuff is concerned. you can't fix the feathering, but i am told that the noise does get worse if you neglect/ignore it.
