BBk Owners PLZ HELP!!
Old May 25, 2010 | 10:04 PM
O HELLA OEM's Avatar
hello i recently purchased a used Rotora 13" Rotora 4/4 BBk . I got them installed from a member here. anyways okie as soon as he got done installing my brakes , i turn on my G and i get ABS,VDC, and Slip lights all come on. Now mind you when VDC is ON my G wont go over 10-15 miles an hour but as soon as i turn the VDC OFF my G runs normally. Now my question is what is causing my G not to go over 10-15mph when my VDC is ON? i asked a Infiniti tech at my local dealership and he said it might have to do with my rear tires being to wide? I have 285/35/19's in the rear. He also said that i needed an alignment and thats what may be causing the VDC to act wierd. what do you guys thing?
Anyone have similar issues like me? he also said i may need to new abs sensors b/c of the ABS LIGHT? he said those sensors are $200 each!!!!!! wtf? if i dont get rid of these 3 lights will i fail state inspection?
any feedback is appreciated thanks!
Old May 25, 2010 | 10:16 PM
gck's Avatar
gck
ill be looking to see the outcome
Old May 25, 2010 | 10:18 PM
psycobusa's Avatar
just a thought, but maybe he could have unplugged an abs sensor or some other sensor and forgot to plug it back in when he finished or maybe accidentally damaged one of the sensors ???
Old May 25, 2010 | 10:38 PM
^may be a possibility but i dont want to buy 2 abs sensor which equals $400. Install them and not solve the ABS light issue
Old May 25, 2010 | 11:28 PM
Footballmania32's Avatar
I think one of my rear speed sensors is going bad. When I drive the car even a little bit hard, SLIP, VDC, and ABS lights go off like a christmas tree. I've learned to live with it, but it is a safety risk. No real solutions for you here, just read the code and follow the bread crumb trail. Good luck!
Old May 25, 2010 | 11:32 PM
does your SLIP,VDC, and ABS always stay lit up? or they only light up when you drive your G hard and then the lights go away?
Old May 26, 2010 | 03:05 PM
Bump
Old May 26, 2010 | 04:35 PM
Glex25's Avatar
Administrator
Check your brake fluid
Make sure your brakes have been bled properly
Could be the ABS sensor not connected or put back on properly if it was taken off to remove the dust shield. Another possibility could be the white cup that has the cut out for the ABS sensor not in tight interfering with the ABS sensor readings
Old May 26, 2010 | 09:50 PM
how do i know if my brakes have been bled properly?
Old May 26, 2010 | 09:55 PM
and will i fail PA State inspection b/c of my ABS,VDC OFF, and Slip lights?
b/c i have to get my car inspected within a month
Old May 26, 2010 | 11:48 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I agree with Glex, check your fluid level. If it is low, those lights will come on.
Old May 26, 2010 | 11:54 PM
so if my brake fluid level isnt full it will cause my ABS,VDC OFF, and SLIP light to be on?
i checked the brake fluid a few weeks ago and its still full. ill check it again 2morrow morning.
thanks EK
Old May 26, 2010 | 11:55 PM
xXHotelCrazyXx's Avatar
+1 on fluid level
Old May 27, 2010 | 12:23 AM
b1gk1d's Avatar
+1 top them of anyway.. happened to me once
Old May 27, 2010 | 01:49 AM
VictoriousG's Avatar
I wonder if you plugged in the obd 2 scanner if it might give you some insight on this.
