ROTOR STUCK!! suggestions?
Old Jun 1, 2010 | 03:11 PM
SKYY-35's Avatar
Exclamation ROTOR STUCK!! suggestions?
Alright, so I got 3 of the four rotors replaced and have had one hell of a time removing the RR rotor because it has severely corroded around the hub. I've used a wire brush to clean it, sprayed WD-40 like crazy. Banged all around it to see if it would break some of the rust off and nothing. There's a plate that covers the back side of the rotor except for the area where the caliper sits.. so I can't get even distribution of pressure. Any suggestions? TIA
Old Jun 1, 2010 | 03:29 PM
GR6RR's Avatar
hand brake is holding it tight... hand brake is backside of rotor.
jus keep bangin all around, it should eventually get loose.
Old Jun 1, 2010 | 03:43 PM
VQ Johnny's Avatar
Bigger hammer and PB Blaster, just keep hitting it, it will break loose eventually.
Old Jun 1, 2010 | 05:00 PM
Lee R's Avatar
Use a rubber mallet and don't be afraid to hit it hard. LOL!
Old Jun 1, 2010 | 05:10 PM
G35Papa's Avatar
PB Blaster around the hub and then hit it all around the area next to where the studs stick out (face of the drum). It will eventually pop. Just got to keep hitting it all around.
Old Jun 1, 2010 | 06:21 PM
walshtj's Avatar
PB blaster and elbow grease
Old Jun 1, 2010 | 07:53 PM
GAU-8's Avatar
Need more than a rubber mallet. Dead blow hammer will be a better choice.
Old Jun 2, 2010 | 12:32 AM
wise-1's Avatar
Internal drum e-brakes are a bytch.
+1 to what everyone else said.
Old Jun 2, 2010 | 05:32 PM
OGKushRob's Avatar
fuuuck it im callin for a heavy duty dremel and cut everything off hahahaha just playin. my dad used his torch for lugs before and **** when they were stuck on then he smashed them off with old man strength!!!!
Old Jun 4, 2010 | 03:31 AM
SKYY-35's Avatar
hahaha well I used the access hole for the e-brake adjuster and started chisseling away towards the hub. Eventually it cracked and on went the show. Thanks everyone..
Kelvin Style006
May 23, 2016 03:47 AM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
Machine Head
Sep 4, 2015 07:22 PM
