SPC rear camber kit/toe bolt help
Old Jun 11, 2010 | 12:32 PM
fatlip's Avatar
I got my front installed but the rear kit is missing a washer and a nut for the SPC toe bolts. The rear suspension only has a 3/4" drop. Would I need the toe bolts if I put the rear camber kit on?
Old Jun 11, 2010 | 01:25 PM
G35Papa's Avatar
You should be able to get back to or close to OEM specs with a 3/4" drop. You probably could have done without the camber arms in the rear also with that mild a drop.
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
