Satellite Radio Reception
2003 G35 Coupe - Need some suggestions as to why my satellite radio is working intermittenly. All other options, CD, FM/AM, cassette work fine. I have contacted Sirrius and they have run tests and diagnostics, stating no problem from their end, must be in the receiver. Where is the receiver? I am guessing it may be in the trunk, under the rear seat shelf. I am assuming it was on the car when new, either from factory or dealer installed. I am hoping it is nothing more than a loose connection. I had a similar problem on another vehicle in the past which was cured with merely a gentle thump.
Any thoughts, insights will be appreciated.
Yep, I found it. Disconnected and reconnected the receiver from wires hoping the problem just MAY be a small amount of oxidation on connectors. Probably, in my dreams . . . . . Thanks for the response!
Thebaws11
Jul 2, 2021 11:36 AM
Learned Hand
Oct 1, 2015 09:02 AM
