rpm at 70mph
Old Jul 6, 2010 | 12:24 AM
rizle021's Avatar
rpm at 70mph
i have a 06 g35 coupe with a automatic transmission, just curious, at 70 mph(in drive) my rpm is close to 3k, is this normal?
Old Jul 6, 2010 | 12:29 AM
NachoCheese's Avatar
No. My RPM at 70mph is over 9000.
Old Jul 6, 2010 | 12:50 AM
Gsouske35's Avatar
I would say its a little abnormal, Im pretty sure you should be at 3000 RPM at 80MPH
Old Jul 6, 2010 | 01:18 AM
CLEANBS's Avatar
sounds normal
Old Jul 6, 2010 | 01:20 AM
CandlestickPark's Avatar
ill Sedan
+1 for a 5AT 3K RPM corresponds to ~80MPH.
Old Jul 6, 2010 | 01:23 AM
thescreensavers's Avatar
Mr.202?
^+1
yep its ~80mph people have slight differences in there tach
Old Jul 6, 2010 | 01:35 AM
G35_REDLINE's Avatar
are you gonna redline yet?
Old Jul 6, 2010 | 05:57 AM
Blue Dream's Avatar
I drove ttrank's car solo
Not if you've swapped out your diff. I'm running 3250 RPMs at 80.
Old Jul 6, 2010 | 08:28 AM
willcho415's Avatar
what is the normal speed for 6mts?
Old Jul 6, 2010 | 09:46 AM
gary c's Avatar
I'm taking SLICK for a drive this morning, when I get back I'll let you know exactly. You can bet what Marcus posted is on the $$, he's spent a few hours behind the wheel....
Gary
Old Jul 6, 2010 | 10:57 AM
walshtj's Avatar
Yeah Id say its a lil less than 3k. It also depends on what your idle rpm is. Mine is exactly 1k.
Old Jul 6, 2010 | 03:02 PM
Irrelevant's Avatar
My '04 AT at 70 (corrected for slightly larger diameter rear tires) = 2450
At 80 (corrected) = 2800.
If you're showing 3000 r.p.m. at 70 something isn't right. Your tachometer, or speedometer is off, or perhaps your transmission isn't shifting into fifth gear. Have you tried manually selecting fifth to verify it's operational?
Old Jul 6, 2010 | 04:05 PM
rizle021's Avatar
All the gears works normal in manual mode, I have the stock differential. Is there a difference in gear ratio in a 04 and 06?
Old Jul 6, 2010 | 04:10 PM
ill Sedan
Of course Tim. I should have clarified I was talking about stock gears. Since I've done the diff swap (3.3 to 3.5) I went from 2900 to 3250 or so at 80MPH.
Old Jul 6, 2010 | 04:43 PM
rob40wilson03's Avatar
is there a switch on the automatics to turn overdrive off? that's my only guess
