camber kit??? on eibach pro kit and 20" wheel
Old Jul 16, 2010 | 09:08 AM
bolacbolac's Avatar
do I have to install a camber kit on my g35 coupe 2005 if I install a eibach pro kit coil spring (1'' front and 1,1" rear) on a 20" wheels
front: whgeel 20 x 8.5, tires = 245/35
back: wheel = 20 x 10, tires = 275/30
thx and sorry for my english
Old Jul 16, 2010 | 09:18 AM
parhamm1's Avatar
Yes. Definitely rear. Front is at your discretion...
Old Jul 16, 2010 | 09:45 AM
bolacbolac's Avatar
do you think this rear camber is good???
http://cgi.ebay.com/ebaymotors/GODSP...Q5fAccessories
Old Jul 16, 2010 | 10:20 AM
parhamm1's Avatar
No. check out SPC. 1. Godspeed is junk. 2. It doesn't have an extended toe bolt. When lowered and getting an alignment getting toe into spec is what will save your tires. You can get camber to zero, but if your toe isn't within spec then you will eat tires... Get the SPC kit. Buy one used off a member here or on my350z.com for fairly cheap and you'll be set.
Old Jul 16, 2010 | 11:52 AM
Alex305's Avatar
Im looking for camber too is this the one you talking about?
http://cgi.ebay.com/ebaymotors/SPC-R...item439fc94bc5
Old Jul 16, 2010 | 12:07 PM
parhamm1's Avatar
Call that ebay guy up. It doesn't make any sense why they would sell the spc kit for $50+change. That cannot be right... Or go with Ichiba, but just make sure you're getting a rear camber kit with extended toe bolts. Check out the suspension tech area on the site.... You'll learn a lot.
Old Jul 16, 2010 | 12:22 PM
bolacbolac's Avatar
check the difference because at 52$ is the part 72265 and for 180$ is the part 72050
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
