Help My driver seat is stuck and will not move back.
Old Jul 23, 2010 | 12:10 PM
poloavirex's Avatar
Unhappy Help My driver seat is stuck and will not move back.
Last night i was driving and i was trying to adjust my seat my seat would not move back only foward. So i get home move the seat all the way up under the steering wheel thinking its something in the track. now its stuck i can't Drive.
Someone please help on how to move it back, Can i move it back with out the motor???
Old Jul 23, 2010 | 05:54 PM
RiversideS13's Avatar
can you hear the motor is attempting to move the seat or it just no response when you were pressing the adjustment button?
Old Jul 23, 2010 | 07:28 PM
DaTkId's Avatar
this has happened to me a couple of times.... its an indication that the motor is going bad. Although u wont be able to hear the motor trying to move it is ( you can feel it getting hot)......just put your hand in the front and hit the motor pretty good while pulling on the button and your seat will start working again.....seems to only happen if u move the seat ALL the way foward
Old Jul 23, 2010 | 08:55 PM
poloavirex's Avatar
Riverside Nothing is working no clicking only part that work is to bring the seat up and down. i move the seat all the way to the front and now i can't move it back. do u know if i can disengage the motor and move the seat manually
Old Jul 26, 2010 | 04:33 PM
abody711's Avatar
take front facia off the seat bottom (two screws). You should be able to see the motor the powers foward and reverse. Three screws on each side holds the drive motor to seat rails. Remove the six screws and unplug the motor and remove. You can manually adjust the seat with a 10mm wrench. You will need to alternate sides to keep seat moving rearward evenly.
Old Aug 11, 2010 | 02:38 PM
poloavirex's Avatar
ABody
i got it to go back like 2 days before you place the post. i had to turn the gear by hand and the chair started going back. but thanks
i need a new seat
Old Jan 21, 2016 | 05:58 PM
MarioG85's Avatar
Poloavirex,
Did you need to completely remove the motor for this to work? Or did you just remove the cover and twist the gears?
Old Jan 24, 2016 | 05:06 PM
on1wheel01's Avatar
You just bumped nearly a 6 year old post. And he hasn't been active in 4 years. My friend had a fx35 and I had to install a new plastic gear in the motor for the seat to go forward and back.
Old Jul 18, 2017 | 07:41 PM
Alfonso Taylor's Avatar
My driver seat will go forward and back but it won’t go up and down is my motor going back
slider_ua
Jul 29, 2015 04:17 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
brian_z
Jul 20, 2015 01:30 AM
