Paint removal on undertray lip
Old Jul 31, 2010 | 11:41 PM
bjquinnIUmed's Avatar
So when I bought my G used, the dealership resprayed the front bumper, but didn't mask off the lip on the undertray that diverts air to the radiator. As a result, it was sprayed DG as well. After a winter and some parking scrapes, the paint is flaking off in some parts, but still well adhered in others. Anyone got some good recommendations on removing paint from this plastic? I know brake fluid would work, but I was worried it would discolor the black plastic.
Old Aug 1, 2010 | 12:09 AM
miltoda's Avatar
I had the same thing happen when I got a new OEM bumper for my sedan. I've just left it as is, but I think if you put a line of tape along the paint edge you want to keep and knock it down with some 400 or grittier sandpaper it'd come right off. There's probably a better chemical solution but I don't know of any myself.
Old Aug 1, 2010 | 12:41 AM
parhamm1's Avatar
Goo Gone makes a graffiti removal spray. I use it to strip my grill when I paint it black and want to strip and respray it. Can be had at lowes or home depot.
Old Aug 9, 2010 | 12:35 AM
krypton's Avatar
Hi. Just wondering do they just simply spray paint over existing paint on bumper ? without sanding priming etc.
Old Aug 9, 2010 | 09:26 AM
miltoda's Avatar
Typically when a shop repaints your bumper they have to sand down the surface and primer it so that the base coat will stick. If you paint right on top of a smooth clear, the paint won't stick and will peel right off.
Old Aug 9, 2010 | 09:42 AM
walshtj's Avatar
+1 def have to sand it down first. Also goo gone would work great I think. Let us know what you decide to use and how it works out.
jsimonk
Dec 22, 2023 03:49 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
skippyG
Jan 25, 2016 01:18 PM
pasjr1972
Sep 1, 2015 10:17 PM
