speaker system
Old Aug 8, 2010 | 01:04 AM
shorty_87's Avatar
speaker system
so i have an 07 2dr coupe and i replaced the door speakers recently, the factory speaker popped (so sad) i spent a crap load of money on these n the music still sounds like crap in the front.. the entire dash vibrates because of the tweeters... can i disconnect those badboys or will the volume output be too low??
Old Aug 8, 2010 | 01:06 AM
whoozyadaddy7's Avatar
You might get some input here but try posting to the audio, video, electronics section. There are some knowledgeable guys there to help.
Old Aug 8, 2010 | 12:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Define crapload.
Did you do it yourself? What brand/model are your components? How/where was it mounted? Did you install crossovers? Are you running factory headunit? Is it factory Bose? Are you running an aftermarket amp?
Tweeters shouldn't make anything vibrate unless you put them on the tip of a jackhammer.
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
doakley92
Sep 25, 2015 12:58 PM
