Service Engine Soon light on.. Code p0171
Old Aug 9, 2010 | 06:30 PM
naseem641's Avatar
So i installed an aps tallboy in my 04 g35 coupe. The check engine came on after 2 days. Idle was also rough. So i returned to stock, and still same thing. It is throwing the code p0171 "engine too lean". Now i replaced all vacuum hoses where they belong, cleaned maf sensor, tight seal around manifold... I am totally lost guys.. any help would be great before i take it in to the stealership. thanks
Old Oct 18, 2011 | 08:46 PM
Marqmo21's Avatar
p0171
I'm having the same problem, if I get it fixed I'll contact you.
Old Oct 19, 2011 | 05:18 AM
Bulleh's Avatar
auto or manual?
Old Oct 19, 2011 | 06:22 AM
Marqmo21's Avatar
07 G35S sedan manual
Old Oct 19, 2011 | 02:56 PM
PhilsG420's Avatar
Are you modded? You may need a tune to fix your AFR (air/fuel ratio). It could have something to do with your oil as well bad piston ring.
Old Oct 19, 2011 | 03:45 PM
Marqmo21's Avatar
No mods. Just staying lean. Could the injectors on bank 1 be the program
Old Oct 19, 2011 | 03:46 PM
Marqmo21's Avatar
Problem*
Old Oct 19, 2011 | 03:50 PM
Canadian's Avatar
Canada, eh?
Reset your ECU, might fix it
Muski_G
Dec 1, 2023 11:11 AM
derres
Aug 28, 2015 03:27 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
