DynaPAck results in...388rwhp, 329 ftlbs
Old Oct 10, 2004 | 01:28 PM
  #31
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Re: DynaPAck results in...388rwhp, 329 ftlbs
Vortech makes the SC, not Stillen. I paid about 7k total, including tuning.
2 G or not 2 G, there's no question!
Wanna see mine? Click here
Old Oct 10, 2004 | 01:31 PM
  #32
a.k.a. RANDYS_G
There's no bubble bursting Cersoft, cuz you are wrong. A Dyno and Dyna both take their readings at the rear wheels. The hp you see is RWHP. I calculated the dif at the wheels by 15% and it equates to about 453hp at the crank. The only way you can get an accurate crank reading is to pull the motor and put it on an engine dyno...I'm not flaming bro, just informing. How's the SC, BTW....your car is the nicest SC'ed Stillen I've seen...like that hump on the IP.
Old Oct 10, 2004 | 01:47 PM
  #33
StreetrydeG35's Avatar
uh randy..... the dyno sheets clearly state that the hp rating is SAE corrected "FLYWHEEL" hp
and technically you can't just "multiply" the old driveline loss numbers to get "crank" hp because its a common misconception.
think about it this way... lets say your stock car has 30-40 driveline loss.. 30-40hp is enough energy to power a few houses. if you keep the driveline loss at 15% then your current calculations say you're losing and extra 25 hp through the driveline.. thats a lot of energy going poof.
but yea you might wanna recheck the dyno... from what i read it shows "Flywheel" SAE corrected numbers.
Nick
Old Oct 10, 2004 | 06:09 PM
  #34
a.k.a. RANDYS_G
again, and others can back me up...it is impossible to get crank or flywheel hp if the car is tested on a dynojet or dynapack machine. Shawn (at the Dyna place) may have just had the screenset to display the wrong verbiage.....as far as the % off loss ponies goes...you may be right...but I'm sure it's at least 425 or higher...anyone want to chime in on this?
Old Oct 11, 2004 | 07:11 AM
  #35
SteveAreno's Avatar
Yeah, the only way to measure flywheel HP is by, get this, measuring it from the FLYWHEEL. Its probably just a typo on the dyno sheet. Im sure randy would have noticed if his engine was out of the car!!
2004 G35 Coupe 6MT | OB/Black
Premium | Aero | Splash Guards | XM
Z Tube | Pop Charger
Helix Test Pipes
Unorthodox Crank Pulley
Injen SES
DC Sports Headers
Old Oct 11, 2004 | 12:01 PM
  #36
a.k.a. RANDYS_G
uh nick...look at the other posts...looks like typo is the reason...you can also call Shawn at Churches Automotive and verify. =)
Old Oct 11, 2004 | 05:41 PM
  #37
dragon_long's Avatar
Shawn measures from the rear wheel hub(Dynapak), not at the flywheel. His printouts just says flywheel even though it's not.
Old Oct 11, 2004 | 06:44 PM
  #38
a.k.a. RANDYS_G
BTW, Dragon Long knows, his car was tuned by Shawn...Dragon, can you make it out on Wed? See SoCal Forum.
Old Oct 12, 2004 | 11:16 AM
  #39
Sorry bro I can't make it out this Wednesday, I'm flying out to vegas for a convention. Sounds like fun though. I'll hit up the track with you guys one of these days. Good luck on the times. I know you'll do well. I need to make another trip to Church Automotive soon. I need a retune since I last tuned with a stock exhaust and fuel pump.
Old Oct 12, 2004 | 11:55 AM
  #40
just checkin :-p because some dyno programs use a built in algorithm to "determine" flywheel hp.
dynos lie! :P go to the track
nick
Old Oct 12, 2004 | 11:59 AM
  #41
a.k.a. RANDYS_G
I'll be there tomorrow!
Old Oct 12, 2004 | 12:00 PM
  #42
a.k.a. RANDYS_G
no prob...good luck!
Thebaws11
Nov 30, 2016 12:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
