05 g35 coupe...rear tranmission noise.. what do you recommend??
Old Aug 16, 2010 | 06:55 PM
caper's Avatar
So let me tell you alittle background about my coupe. Im 27 and this is not my first manual or sports car. Last car was a porsche
last year with 44K miles, the clutch pedal started going soft...then it wouldnt go back up and eventually it started burning the clutch when i was on the highway and the clutch would only engage a bit.
So dealership said its my problem not theirs and I ended up buying a 1 piece Stillen flywheel and OEM clutch pack. I bought another clutch slave, flushed and it ran great.
Now I am at 82K and the pedal is going soft again...it has started to stick just occasionally which i decided to put it on the lift. It also started making noise when clutch was depressed or in neutral, like a rattling noise.
So on the lift, the rattle was definitely coming from the rear of the transmission...so its not the Stillen flywheel.....
I checked the plug on the side and fluid started coming out so I imagine that means its not low on tranny fluid.
What do you guys think I should do??
I was thinking of putting in Locas or RedLine..something expensive to see if it quiets down the rattle...
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
multimut
Canada
Jul 26, 2015 08:43 PM
laksjd84
Jul 24, 2015 05:12 PM
