hey guys.. im am puzzled.. my car is not overheating every time i drive it... i checked the fluids and they were all fine... it only overheats when my car is in gear (driving around) when i rev it in neutral.. the temp stays the same... i opened up my bottom tray and saw some coolant spill out... any ideas on whats going on?.. its about 1 year old and my only mod that might affect it is my UR pulleys since it squeaks when the car overheats.. im guessin its from the coolant pouring on the belts... i really dont kno.. =(
my fan works... but im not sure if my water pump or radiator is workin
04 6MT DG Coupe: Pop/Z-tube, Nismo Ti Shift, Borla TD Exhaust, UR pulley, 35% Lumar Tint, Custom Box w 10w3v2 w. JL 250/1
Sounds like a hose might be leaking...have you checked all your hoses? Maybe your water pump is slipping due to the belts?
'04.5 TwilightBlue Coupe [AT5]//Willow Leather//Premium Pkg//Perf. Tire & Wheel Pkg//Sunroof//Splash Guards//Sirius Sat Radio
i found out that im leaking coolant all over.. its not my water pump belt.. but probably leaky hoses..
maybe not your belt but how about the water pump itself? Usually you will see a hole on it and thats where it should be spewing it out.
S13/SR20 for sale
S13/SR20 for sale
Hopefully a 1 year old car will not have this problem :P
Important that owners review their factory service manual, as the water pump is internal to engine and is driven by the cam chains!
What most know historically [external water pumps driven by a belt] doesn't apply!
4 bolt access cover in the 1 o'clock right front position.
Thanks for clearing this up Q45tech, I didn't know it was driven by the cam chains (I don't have a service manual
well im taking it to dealer.. hopefully they wont give me crap about me having the UR pulleys
