05 G coupe with several problems. HELP!
Old Aug 24, 2010 | 11:42 PM
nate704's Avatar
hello members,
I got 05 coupe and I need a lot of help finding the problem.
1. TPMS light came back on AGAIN 2 days after the reset by the dealer.
2. OEM BOSE HU doesn't play any CDs. it just says "CHECK DISK"
3. when I set the e-brake, the e-brake light on the dash doesn't come on at all.
4. went to dealer, and the tech said compression rod bushings cracked and estimated cost was $940 USD. I thought it was covered by the powertrain warranty?? any input for this?
any thoughts and inputs are welcome and appreciated!
thank you guys in advance!!
Old Aug 25, 2010 | 03:19 AM
herrschaft's Avatar
Just about anything dealing with the suspension are considered wear items and are not covered by the warranty.
If you still have the full warranty the dealer will fix #2 for free.
Old Aug 25, 2010 | 03:43 AM
jibberjabbers's Avatar
Compression rod bushings would be replaced by warranty. Several members actually got theirs replaced under warranty. I went it to get mine replaced but they told me that the bushings were "fine" for now.
Old Aug 25, 2010 | 07:22 AM
scrapiron7's Avatar
I had this same error, and my radio was replaced under warranty.
Old Aug 25, 2010 | 07:48 AM
grovefromnh's Avatar
Doesn't someone make some compression rod bushings out of polyurethane?
Old Aug 25, 2010 | 03:45 PM
t.lynch's Avatar
Every once in while my CD player wont play a cd. Try cleaning the disc and inside of the radio where you put the cd in.
Old Aug 26, 2010 | 01:03 AM
herrschaft's Avatar
I specifically asked if the bushings were covered under warranty and the dealership told me they weren't.
Old Aug 26, 2010 | 09:56 AM
nate704's Avatar
hmm. i guess i have to buy the compression rods from somewhere.
Also, i will try the cleaning CD method first, before i start looking for the new OEM HU.
BTW, how much does the stock used and good working HU goes for?
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
newg37
Jul 26, 2015 09:32 AM
