3.9/4.08 final drive mod...
Old Aug 29, 2010 | 08:59 PM
johnsonp's Avatar
i hear this is a good bang for your buck mod for rev ups but what about 5at's? also what is the difference between each besides the price?
Old Aug 29, 2010 | 09:14 PM
herrschaft's Avatar
Doesn't matter if you have a 5AT or 6MT, I went from a 3.5 to a 3.7 and its definitely noticeable. The higher the number the shorter the gears (quicker acceleration). However, going with that high of a ratio may mess with the car's systems. So far I have not had any problems but I didn't change the ratio too much. Your speedometer will read faster then your actual speed as well.
Old Aug 29, 2010 | 10:28 PM
walshtj's Avatar
+1, speedometer will be off but this also happens with aftermarket rims that are different sizes. Would def be a good mod for autos, what is the price range?
Old Aug 29, 2010 | 10:29 PM
johnsonp's Avatar
cool...
yeah sounds good but everywhere i look online it says it wont fit an auto only manual
Old Aug 29, 2010 | 10:31 PM
johnsonp's Avatar
price...
about 600 for 3.9 about 8-900 for 4.0
Old Aug 29, 2010 | 10:37 PM
herrschaft's Avatar
It depends:
My current diff came off a G37s sedan and required no fabrication. Some will have an extended pinion shaft and 3-bolt flange but its not hard to make these work on any G35.
These threads have the info required:
https://g35driver.com/forums/drivetr...tial-swap.html
https://g35driver.com/forums/drivetr...-into-5at.html
True, but its more like 10mph off with this mod
Old Aug 29, 2010 | 11:02 PM
stbeeman's Avatar
Is there a way to correct that with the car's electronics?
Old Aug 30, 2010 | 12:31 AM
jrockstarr's Avatar
how much will these shorter diffs actually shave off of quarter mile times?
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Frostbite91
Aug 20, 2015 07:20 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
Ninjay16
Jul 20, 2015 01:21 AM
