My review the 3.5 VLSD swap into a 5AT
Old Mar 6, 2010 | 02:38 AM
DaveB's Avatar
Today we finally got a huge break in the weather (60 vs sub 40s) here in KC so I decided to take the day off and install my 3.5/VLSD carrier (aka pumpkin) that I've had for 6 weeks.
Install was pretty simple, but it is a bit time consuming. If you're going to tackle the job, make sure you have at least two decent jacks and a full set of sockets, extensions, breaker bar, torque wrench, various metric wrenches, and PB Blaster (rust eater). I'd also suggest fabbing up wood board to mount on a jack so that you can support/lower/raise the carrier. It also does a great job of getting the midpipe back in place. I used an 8X16X3/4 piece of board. Worked great. I should have made that part years ago.
I won't go into a bunch of detail about the install because there's already a DIY (https://g35driver.com/forums/engine-...pkin-swap.html). However, every DIY I've read fails to mention that you need to remove the driveshaft heat shield and driveshaft support bar (catches the driveshaft if the U-joint were to break). IMO, removal of the midpipe and swaybar are mandatory. I have read that one person did the swap without removing these parts, but I don't see how it's possible. Once the middy and sway bar are out, it's a very easy process. Just take your time. From start to finish, it took me 4 hours, but I also regreased my rear sway bar and diligently cleaned up rust nuts and bolts.
Normal driveability doesn't really feel all that different. However, when you hit it from a stop or roll, if definitely has some extra punch that wasn't there before. Overall, the drivetrain feels more responsive and the higher gears are more useable. The VLSD is pretty nice when hitting off-camber turns.
And yes, the cruise control still works, at least it did when I set it at my normal 75mph cruise speed. I haven't tried anything higher.
Old Mar 6, 2010 | 04:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
Glad you like it. I've been very happy with mine. I had a friend in the car recently that drives a 6MT and his comment was "Man this thing really pulls now".
Curious to see what the 3.7 would've done.
Old Mar 7, 2010 | 06:49 AM
Blue Dream's Avatar
Never satisfied are we? Moditis is a beyotch...........
Old Mar 7, 2010 | 08:31 AM
GT-ER's Avatar
Because coupes don't have those parts.
Old Mar 7, 2010 | 10:49 AM
DaveB's Avatar
Well sedan owners beware then
After a day of driving, my opinion is that this is the way the car should have come geared from the factory. The gears aren't overly short and that 1st to 2nd slight lag between ratios is gone. I'm surprised that a 6% difference in gearing could improve the feel this much. I am curious to see the impact to MPGs, but even then, it shouldn't be too significant.
Old Mar 7, 2010 | 11:28 AM
Blue Dream's Avatar
I lost less than 1 MPG after I did the swap. Well worth the gain.
Old Mar 7, 2010 | 10:43 PM
OCG35's Avatar
now that you've come around to experience what many of us have been stating - maybe you should give the tbs a try... the driving experience that I have stated with tbs is as accurate as what I've said about the fd (which you are now experienced as well)...
Old Mar 7, 2010 | 11:40 PM
GT-ER's Avatar
If TBS means Throttle Body Spacer then I see no scientific reason for a TBS to work. Final Drives on the other hand have a mathimatical reason behind them.
Old Mar 7, 2010 | 11:47 PM
OCG35's Avatar
the post want an invitation to open debate about the unit... it was in reference to DaveB's new found confirmation that the FD is a worthwhile mod (something he had questioned in the past)...
Nothing more than suggesting he give it try.
Old Mar 7, 2010 | 11:52 PM
Jeff92se's Avatar
Red Card Crew
I think he was referring to the reasoning behind deciding on a mod.
Old Mar 8, 2010 | 12:11 PM
DaveB's Avatar
For the most part, I knew what this setup would feel like since I've run 24.5" tall DRs at the strip which gave the car a theoretical rear ratio of a ~3.6. I had never driven around town with the setup though. It drives very nicely so thanks for the convincing. I'm still perplexed about the CC issue so many have reported. Like others have pointed out, there must be an MPH that when exceeded, flakes out the CC. I've set my CC has high as an indicated 77mph and it still worked.
As for the TB spacer, I don't think I've ever really doubted that it can improve throttle response (that part makes sense) to a small degree, but I don't buy into the rifling of air.
Old Mar 8, 2010 | 12:37 PM
OCG35's Avatar
^^^ too bad you wouldn't agree to try it (for ***** & giggles) when I had a spare to loan out...
if you have a chance to try one (the one I'm referring to) - give it a shot for the helluvit - only takes 15 min to install and uninstall... It would be good to have you give first hand thoughts (good or bad) like the FD.
Again - for the peanut gallery... this isn't a seed to spark a debate about the mod - so save it...
Old Mar 8, 2010 | 12:42 PM
KSWAY's Avatar
My CC worked for about 3 days after the install of my 3.7.
Old Mar 8, 2010 | 12:44 PM
OCG35's Avatar
3 days?
mine has worked for two years (or however long its been)...
Works to 90... it doesnt turn off at 90, just wont go past 90 - and wont engage past 90.
