pull out and traffic and clutch pedal gets stuck down....
Old Sep 9, 2010 | 11:12 AM
jardoeli's Avatar
Also a quick cheap fix is to install a stainless clutch line. Its like $20-$30.
And put in DOT4 brake fluid.
I did this and my clutch feels much better than before!
However, my pedal never stuck to the floor. Almost did once when it was REALLY hot outside in traffic. Didn't take any chances and changed the line. Never going back to stock line....EVER
I do traffic every morning and night. At least 30-60 minutes one way. The stainless line is a must!
Old Sep 9, 2010 | 01:52 PM
BolivianFuego's Avatar
Originally Posted by Beebo
same happened to me... i thought it was the slave/master cylinder but it turned out there was a leak in the hose
Bingo. Just go check first, cheapest thing is to re-bleed the slave, see whats the problem from there. Is
Is there dripping from the hose? If not its probably the slave, and that too is cheap to change.... but why buy something if all you need is to re'bleed your slave?
Sounds like overkill. This sounds like air got into your lines and a simple bleeding of the slave would have made it feel as good as new! But to each their own.
Old Sep 9, 2010 | 02:08 PM
jardoeli's Avatar
It isn't believe me. I bled it 3 times in 1.5 years. Either the fluid (DOT3) was getting dirty or contaminated very fast or the stock line just plainly sucks... I dunno.
But when I fix something, I like doing it once and doing it right.
Look at it this way:
1 hour labor ( I did it with help from a family member)
$30 for the line
No more problems
You can't beat that!
magnetism80
Feb 1, 2019 10:00 AM
jbmw002
Sep 10, 2015 12:54 AM
yosip1115
Sep 9, 2015 03:30 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
