weird buzzing/humming noise
Old Sep 6, 2010 | 01:29 PM
jvm0685's Avatar
so i got my brakes and rotors replaced not too long ago. i put in brand new slotted and dimpled rotors and hawk pc pads. I've noticed that whenever I drive (brakes are not being applied) there's a weird humming/buzzing sound coming from what I think is my brakes/tires area. Is this a result of the slotted/dimpled rotors? The sound sort of sound like buzzing overhead electric wires make. Is it the wind blowing across the surface of the rotors?
Old Sep 6, 2010 | 01:44 PM
Lone Wolf's Avatar
Is it coming from all four corners?..or is it just coming from one corner...It sounds like a wheel bearing(s) is going bad..I had my right rear wheel bearing replaced about two months ago..it sounded like a crackling/popping sound..also if I was driving with my windows up, radio volume at 0 the bad wheel bearing had a wind tunnel affect sound.
Old Sep 6, 2010 | 01:46 PM
jvm0685's Avatar
I'm not sure if it's all 4 but it's definitely the front two. Is there a way for me to check the bearings?
Old Sep 6, 2010 | 02:16 PM
Lone Wolf's Avatar
check for a DIY on here..when the tech who worked on my car showed me the bad wheel bearing it had a very slight resistance when spinned...your best bet is to take them off.
Old Sep 6, 2010 | 03:27 PM
jvm0685's Avatar
so i just jackets up my front wheels and spun them and i heard a scraping sound. i think when i had the pads installed they werent pushed in all the way and now theyre scraping up against the rotors even when im driving.
Old Sep 7, 2010 | 04:18 AM
sketo's Avatar
Hey I just got a 6mt coupe last week with brembos and noticed a loud rumbling noise at low speeds (say coming to and leaving from a stop sign). It's there whether if brakes are being applied or not. However, what I did notice is that the alignment is a tad off and am hoping that will resolve the issue. Otherwise, it will be a slew of mechanical trial and error to resolve this. Please let me know if your brake adjustment makes any difference.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
