engine makes wierd screeching noise
Old Sep 11, 2010 | 10:08 AM
Sammy23's Avatar
hey guys, 05 coupe 5at 67,000 miles.....
whenever i start my car, after about 30 seconds it starts to make a high pitch sceeching sound..and 30 seconds after i turn the car off it makes the same noise.....i have a short ram intake and a motordyne 1/2 spacer but its neither of those because the noise was coming before i put them on....im guessing it cant be the belts because the noise still happens after i turn the car off...it sound like its coming near the plenum area could it be a loose hose...idk what do you guys think.....and if its a hose or vaccum how to find it???
thanks
Old Sep 11, 2010 | 11:32 AM
gary c's Avatar
The noise you describe is generally the belts being worn or loose when you start the car but I can't think of a thing that would make that noise after it's shut off....even a vacume hose. Have you given us a puzzle for which there is no answer?
Gary
Old Sep 11, 2010 | 03:31 PM
jef_gutjr's Avatar
^^ Gary is right, it sounds like a belt, maybe the one that runs your alternator. If you have a vacuum hose loose or leaking, your rpm should be jumping up and down which means vaccum or boost leak.
Old Sep 11, 2010 | 04:43 PM
Sammy23's Avatar
Old Sep 11, 2010 | 04:45 PM
Sammy23's Avatar
the car was on..and once i turned it off this noise came. i hear the same noise when i start the car and am letting it warm-up...ahhhh what could it be...around 37 seconds into the video is what im talking about
Old Sep 12, 2010 | 12:14 PM
Ep Drifter's Avatar
just saw the video and that sounded horrible!!
Old Sep 12, 2010 | 12:19 PM
w4kj4k's Avatar
Dude.. that sounds like a ghost screaming at you
Old Sep 12, 2010 | 12:54 PM
Sammy23's Avatar
Know man. I hate it when people compliment my car and then ask me if it's gonna blow up lol.... But what do u guys think it is? It is really starting to annoy me...someone told me to run a "smoke" threw it? To locate if it's the hose...others suggest going back to stock intake.....idk any ideas? Trying to get it worked out soon
Old Sep 12, 2010 | 08:12 PM
jutn35's Avatar
G35 Coupe
in for the problem ...........
Old Sep 12, 2010 | 08:53 PM
Mike Mike17's Avatar
it sounds like a sound from a horror movie
Old Sep 12, 2010 | 09:17 PM
HangUp n' Drive's Avatar
The check valve between the engine and brake booster? EVAP system? Air conditioning freon pressure equalizing (if using AC). Not sure what parts could cause this in the AC or EVAP, but defiantly some places I would look. Finding small vacuum leaks can be done with a can of WD40 or similar, use the plastic nozzle and spray suspect area, the oil will be drawn into the leak temporarily sealing it, causing a change in RPM.
Old Sep 12, 2010 | 11:56 PM
nicbaines's Avatar
i would say that the ac pump is going. seals are not holding freon pressure, and it is just equaizing. just my $.02
Old Sep 13, 2010 | 02:31 AM
jef_gutjr's Avatar
Originally Posted by Sammy23
Wow, that sounded a little scarry. Sounded like a door opening during a horror flick. I honestly don't think that is your belts. Take it to a shop and see what they say....Good Luck
Old Sep 13, 2010 | 03:21 AM
herrschaft's Avatar
Is your car's name "Christine"?
Old Sep 13, 2010 | 10:26 AM
djamps's Avatar
Sounds electrical to me. Aftermarket alarm system? How do the engine grounds look?
