ABS/SLIP/VDC Lights on after SPC kit
Old Jan 22, 2011 | 01:28 AM
  #31
RedHot6mt's Avatar
Originally Posted by herrschaft
If you remove the shims, then yes you should be able to get the car back within spec.
What year is your car? Not saying that this is a fact but I've concluded that the newer models (05/06+) don't have as much camber issues as the first gens.
I have and early 2003 Coupe:
Old Apr 4, 2015 | 04:16 PM
  #32
SuperGTR's Avatar
Spc front camber kit abs/slip/vdc off lightts on after installation
I know this is an old thread but i was able to FIX this problem.
After I installed the SPC kit with the spacer and ABS relocation the car started to make this weird spring sound coming from the front left of the car and the SLIP light would come on 3 times.
I learned that the air gap between the ABS sensor and the wheel hub was off.
So i added 2 washer/shims to the screw securing the sensor and the problem was still there.
I ended up removing all shims and the braket that came with the kit and installing the sensor as it was installed before (just a screw with a washer and the sensor) But i put it on top of the new screw that was provided when i did that on both sides all the lights were still on so i drove around for 10 sexonds and they all went off havent had a problem since.
Jusseth
Sep 13, 2020 12:25 PM
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Freddy07g35
Sep 17, 2015 08:53 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
