Wider tires
Old Sep 20, 2010 | 02:16 PM
jef_gutjr's Avatar
Wider tires
I have SSR VF1 19x9.5 +25 front and 19x10.5 +22 rear, and I am running Bridgestone 760 front 245/35 and rear 275/35. I am really not happy with the set up because the wheels stick out in the front and rear. Thinking of running 255/35 front and 285/35 rear. I guess my question is would this work? Car is dropped with tein s tech's... Going with Bridgestone RE-11...
Old Sep 20, 2010 | 02:29 PM
Silencer_0's Avatar
What do you mean they're sticking out? They can't be sticking out with those offsets....
Got pics?
Old Sep 20, 2010 | 03:10 PM
partyman66's Avatar
So your car looks like a matchbox car?
Sounds pretty Schweet to me!
Old Sep 20, 2010 | 10:32 PM
jef_gutjr's Avatar
Got pics?
The bead of the tire is not flushed on the rim itslef. So I'm thinking of going 255/35 front and 285/35 rear. Anyone running this setup? Do I have to roll the fenders?
Old Sep 20, 2010 | 10:38 PM
Deezflip's Avatar
he wants the tire itself even with the rim. You should get what your looking for with the 255 on the 9.5, and the 285 on the 10.5. you might need a slight fender roll in the rear if you want your camber close to spec since you're lowered with eibach camber kit.
Old Sep 20, 2010 | 10:39 PM
Silencer_0's Avatar
Ah, I get it. You don't like poking. Yeah, you should be fine with that setup.
Old Sep 20, 2010 | 10:44 PM
Deezflip's Avatar
OP, these threads might change your perspective on sizes...
https://g35driver.com/forums/media-s...ost-em-up.html
https://g35driver.com/forums/picture...m-up-1052.html
Old Sep 20, 2010 | 10:49 PM
jef_gutjr's Avatar
^^ wow those are pretty sick pics. Anyhow, yah I got s-techs with eibach cam kit in the rear. I am going to try the wider tire set up and see if I have to roll em if that's the case. Thanks for the help !!!
Old Sep 21, 2010 | 01:38 PM
herrschaft's Avatar
^Get tires that actually fit the rim...
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
