Engine oil Brand
Old Sep 26, 2010 | 01:42 AM
whoisthis's Avatar
Originally Posted by gary c
Whoisthis, that doesn't sound great. You're using 0W/30, it's possible that's too thin. Next oil change switch to 5W/30 and see if that noise persists. I've been using 10W/30 AMSOIL with K&N filters, you can't tell when my engine is running. I often have to look at my tach to tell if it's running....
Gary
Can i try 5w40 penzoil platinum next time?
How much did you pay for amosil oil?
Old Sep 26, 2010 | 01:44 AM
thescreensavers's Avatar
Mr.202?
^ just try 5W/30 which is what is ment for our cars normally.
PP is good. Syntec is good
Old Sep 26, 2010 | 01:47 AM
whoisthis's Avatar
By the time i change the oil next time, I'll probably be into drifting. So i want something that good for high temperature and for daily driving
Old Sep 26, 2010 | 07:19 AM
grovefromnh's Avatar
0w30 is great if you live in Alaska.
Old Sep 26, 2010 | 07:42 AM
xXHotelCrazyXx's Avatar
AMSOIL is the only oil i trust in my car...lots of studies done to back up their oil also.
http://www.amsoil.com/performancetes...veOilTest.aspx
Old Sep 26, 2010 | 07:43 AM
http://www.amsoil.com/performancetests.aspx
Old Sep 26, 2010 | 11:04 AM
gary c's Avatar
If this....^....is what you're going to be doing with your G35 the engine noise you're complaining about will be the least of your worries....
Gary
Old Sep 26, 2010 | 11:13 AM
Mr.202?
I hate it when people post these tests they are pointless. They would need to test all the oils in the VQ for it to be anywhere near useful.
Just because the oil did better in there tests does not mean it will be better in.your engine.
here is a chart of oils ran in the VQ
Nothing here screems at amsoil being king, I do not think its worth the cost > Castrol Syntec
Old Sep 26, 2010 | 01:58 PM
V35 Skyline GT's Avatar
6MT Coupe
^ True oils perform differently in different engines, but those are very old comparisons and very out-dated for the VQ. Resolute has yet to update with current UOA compiled results. He took those old averaging comparisons off his thread a long time ago for that reason and also for another... Proprietary oil formulations change all the time.
I know, Castrol makes my engine run really smooth but the ONLY bad thing is I hear ticking/clunking sound. I don't know if this could cause a problem in the future.
I meant to say mobile one 0w40.
That's mostly a Group IV (PAO) base with Group II+ or III to hold the add pack in solvency. One of their better formulations if you're a loyal M1 user imo.
Your vids:
IMO, it's not the oil (unless you're low on oil) but rather an internal metallurgy condition.
Old Sep 26, 2010 | 02:06 PM
Mr.202?
^ they might be outdated, but look into recent UOA most of the ones I looked at which were green on that chart are still good now.
anyhow He should have a new chart out soon.
Old Sep 26, 2010 | 02:54 PM
whoisthis's Avatar
Why am i the only one having ticking sound in my engine with Castrol 0w30..!! I like this oil but the damn noise.
Old Sep 26, 2010 | 02:56 PM
whoisthis's Avatar
Gary
I could careless if the noise was there before the oil change, but after oil change, I hear the noise.
Hey, will i be ok if i add some Mobile 1 5w30 or 10w30 in to my engine because the dipstick reads little less than high Point.
Old Sep 26, 2010 | 02:57 PM
whoisthis's Avatar
Nothing here screems at amsoil being king, I do not think its worth the cost > Castrol Syntec[/QUOTE]
Is there a result out there for 5w40 PP?
i never knew Shell makes good oil for our engine
Old Sep 26, 2010 | 10:58 PM
Hate on. They are pointless if you dont understand them. Im not a fluid engineer, nor do i do the studies and testing. That is their job. Not mine. Im going off of experience from several good friends that track their built cars at virginia intl raceway. Usually they have to rebuild their engines every 3 good full running days from being at the track and they are averaging 10-11 runs now since they have switched to amsoil. If never heard of anything bad from amsoil. Its all been good reviews from what Ive read and word of mouth. Its personal preference.
Old Sep 26, 2010 | 10:59 PM
  #30
Fuel solenoid most likely
