Bought a 05 G35 2 months ago, now problems? o.0
Old Oct 16, 2010 | 10:19 PM
superdkracing's Avatar
Dear sirs, please see if you will be able to identify what the problem is.
I am not sure if it is because the weather has turned cold these days, on startup, I would get this gasoline smell coming from the exhaust but not from the hood. Is this normal? It never did that when I bought it 2 months ago until just recently..
Another problem I noticed is during the first startup of the day, I get a mild rattle sound from the bottom of the driver seat, under the car. I checked several times and it is not coming from the engine. Is something loose under the car? It also started to happen since the weather turned cold..so I am not really sure if its 'normal'.
The only thing I did was a complete oil change and differential fluid change, and pulley for the steering at Mr. Lube. Could they mess up something over therE? The guys really looked like they know their stuff, and the mech who did it for me also owned a G35 coupe , and the car drove PERFECT no sound no rattle whatever when I first got it..
Thank you so much guys, I am worried because I spent pretty all my savings buying the baby.
Old Oct 16, 2010 | 10:23 PM
_'s Avatar
_
let the car warm up then drive?
Old Oct 16, 2010 | 11:02 PM
gary c's Avatar
Smelling gas fumes at the tailpipe means unburnt fuel which could be a plug not firing or only partially. Have a qualified mechanic check this out for you, shouldn't be anything too serious. Just don't go to Infiniti, Nissan's a much better choice or like I said "qualified mechanic." Maybe you shouldn't be sniffing the tailpipe....
Gary
Old Oct 17, 2010 | 02:10 AM
krypton's Avatar
Since weather turned cold, I notice same behaviour with gas fumes. I assume it's normal
Old Oct 17, 2010 | 02:15 AM
krypton's Avatar
As for rattling, make sure you are turning ignition key all the way and keep in it on position for a second before releasing.
I noticed rattling sound when I do it too fast in cold weather.
Old Oct 17, 2010 | 03:49 AM
Canadian's Avatar
Canada, eh?
Your second issue is not a problem, it is the ABS system running a check and is competent normal. Happens when you start the car only. Your first issue also doesnt really sound like a problem, maybe you have test pipes.. But I wouldn't worry at all.
Old Oct 17, 2010 | 03:09 PM
adamls2's Avatar
Canadian is right and the gas smell is also probably from the cold weather
Old Oct 19, 2010 | 03:53 AM
updated~ it turns out to be a rusted cat. heat shield almost falling off...so I just got the mech to yank the thing off.. He said its not big deal as long as I don't park on grass.. is it alright then? or where would I find spare parts?
Noise is finally gone!! and now my TIPS light is on...lol...wtf ~!! thanks for all the help guys!
Old Oct 19, 2010 | 04:01 AM
Eric@TCGMiami's Avatar
If you're smelling gas chances are that it's a cat converter. Cats convert that gas into more environmentally friendly waste. whenever a cat fails it doesnt kill the gasses thus you smelling gas in the cabin..
with that said, if you are getting a Check Engine Light after the heat shield removal (the rattle you had) you eliminated 1 of the problems (the rattle). the other problem is still there which is an exhaust leak.
Chances are either the cat is cracked or flange/oxygen sensor is loose.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
tiguy99
Jul 26, 2015 01:39 PM
apintojr
Jul 23, 2015 10:52 AM
Lsantana757
Jul 20, 2015 09:08 AM
