Tire Question...Plz Help
Old Oct 19, 2010 | 11:54 AM
avinashchanagal's Avatar
Red face Tire Question...Plz Help
I'm trying to replace my fronts with the backs 245/45/18 and putting 265/40/18 in the back. But when i went to tire shop, the mechanic scared me that it's gonna messup the transmission........ so i didn't do it.
Also I'm gonna put them on the company OEM rims....... have any of u guys done this........ would it have any effect on the transmission and the driveability of the car? Also would the 265/40/18 fit on the oem rims.
PS: I don't have any spacers and the car is not lowered.
Thanks for any help guys.
Old Oct 19, 2010 | 09:39 PM
Itzmy04G35's Avatar
I understand what the tech was saying about the transmission, had the same problem with my silverado when i started running 37's instead of the factory 29". HOWEVER, i can't imagine that what...3/4" per tire would effect the transmission that much if at all....however i am a noob when it comes to G's....
Old Oct 19, 2010 | 11:18 PM
vannns's Avatar
If I understand you're question, you're trying to put a bigger size tire in the front?(your switching you're front tires for your back ones and adding new tires on the rear?) What are stock tire size for the G's? I don't know much about G's or car but what I can tell you is putting bigger tires might give you some rubbing action on your fenders/wheel-well , or make you go a faster speed then what your speedometer say's from what I know, sorry I couldn't really answer you're question.
Old Oct 19, 2010 | 11:53 PM
MyaLover's Avatar
I don't think you'll have transmission problems (this usually only happens with AWD cars with different sized tires). But you will indeed have a problem with your speedometer being off.
Do the right thing, just buy new fronts now and new rears later.
Old Oct 21, 2010 | 08:33 PM
Thanks guys. I have decided not to put them on.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
