whats a dropped clutch?
Oct 20, 2004 | 02:26 AM
what does it mean to drop your clutch?
or what is a clutch drop?
it is bad for your car right?
G35s6mt/TSecu/350Z Springs&Struts/K&Nfilter+Z-tube/StillenDualExhaust /6WireGroundKit/KinetixHighFlow
Reply 0
Oct 20, 2004 | 02:41 AM
Re: whats a dropped clutch?
Pick up your clutch.
Now let go. You dropped your clutch *rimshot*
Okay, but seriously... When you rev up your engine with the clutch engaged, then release the clutch quickly with your tach up, you've dropped your clutch. Most of do a slow release from a red light- you balance your clutch and gas to get a good launch. When you've dropped your clutch, you've just basically gone to 2k and let go of the clutch in a split second.
Not the best thing for your car, which is why I only do it on Fords.
G
"If my critics were told I could walk on water, they would say, 'But he can't swim.'"
Black/Willow Sedan. Check profile for specs.
<font color=red>B.A.S.T.A.R.D Squad</font color=red>
Reply 0
Oct 20, 2004 | 07:11 AM
good definition.... definatly hard on clutch and tires..... not something u wanna do unless ur at the track and even then.... haha i wouldnt want to do it in a car that i cant afford new tires or a new clutch on
2004 Black on Black g coupe 6spd.... aluminum pedals, clear corners, z tube, and pop charger. soon to have 19" volk gt-c's and PIAA xtreme whites in the clearance and corners
Houston Texas
Reply 0
Oct 20, 2004 | 02:18 PM
It's also referred to as "dumping the clutch"
A "dropped tranny" would mean that your transmission died, could this mean the same thing for the clutch also?
2004 6MT DG/G Coupe | Premium | Aero Kit | ClearBra | See profile for pix
Reply 0
