Sunroof adjustment
Old Nov 1, 2010 | 10:26 AM
atmel101's Avatar
Sunroof adjustment
When my sunroof is closed on my 04 coupe I hear creaking and whining sounds when I turn or go over sidewalks. At first I though it was the plastic trim near the back window, but it's definitely the sunroof.
If I press up on the glass or drive with it open I hear no more noises.
Other than the noises there is no water coming in or debris on the tracks.
The tracks look well greased, thee car has never seen winter .
I read a TSB saying that the sunroof can be adjusted if not level with the metal when closed, but I have no idea where the adjustments can be made.
Does anyone have any idea? am I the only one with such a problem?
THX !!
Old Nov 1, 2010 | 01:46 PM
spoolinupblue's Avatar
Hope this helps
Old Nov 1, 2010 | 01:56 PM
atmel101's Avatar
That helps, thanks !! I will give it a shot
Old Nov 4, 2010 | 11:36 PM
atmel101's Avatar
Does anyone know how to remove those inner blinds ... I can't get the bottom portion off.
In the diagram above its the pawl ...
Old May 3, 2012 | 12:10 PM
Bphillips330's Avatar
Not to open an old thread. I am having the same problem. Did you ever get this fixed?. I was going to remove the headliner and see if there are bolts I can adjust or tighten just because I hear stuff Rattalung around up there. If there is an easier way with out having to remove the headliner. Please let me know
Old May 4, 2012 | 07:16 AM
atmel101's Avatar
Sorry dude, I never resolved this problem.
Post pics if ever you get to the root cause.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
