pcv valve
Old Nov 13, 2010 | 06:17 PM
ShaneH85's Avatar
pcv valve
I have searched and searched on here for a diy pcv valve change and a fuel filter change and either I'm just not typing the right thing in or I'm a complete idiot. Any help would be much appreciated.
Old Nov 13, 2010 | 07:19 PM
gary c's Avatar
Shane, the gas filter is inside the gas tank and doesn't require changing for a long time. I asked the same question a few years ago cause I was used to changing them on my Z. Facing your engine I believe the PCV valve is under the first hose on the left valve cover. Remove and shake it, if it rattles put it back your good or if it doesn't rattle fill it with carb cleaner with your fingers on both ends shake it until it rattles and you're done except blowing it out. As long as you can clean these valves they never need replacing....
Gary
Old Nov 13, 2010 | 07:31 PM
ShaneH85's Avatar
Gary
thanks man, i feel like an idiot, i walked outside and went right to it, mine had a little oil in it? But i took it out and shook it and it rattled so im assuming its ok. And to think i was b****ing about this thing when i changed my plugs today.
Old Nov 14, 2010 | 09:38 AM
SpForces's Avatar
What made you think the valve was having a problem?
Old Nov 14, 2010 | 10:58 AM
ShaneH85's Avatar
Well I have a damn nosie that almost sounds like a motor knock when my car is at operating temp, but I think that is from my clutch or throw out bearion bc when I put it first and let off the clutch the noise goes away. Also another thing is my car idle is way low, when its warmed up my cr idles at 200 rpms
Old Nov 14, 2010 | 11:01 AM
gary c's Avatar
You don't need to have a problem to check the PCV valve, it's like fluid levels and belts....common sense tell you to check those especially on a high mileage G....
Gary
Old Nov 14, 2010 | 08:43 PM
SpForces's Avatar
Gotcha didn't realise that ones one of those things. At any rate I checked mine today and it was all good. What are the symptoms of a bad one, I guess that is a better way to ask for the info I was looking for.
Old Nov 14, 2010 | 09:14 PM
Project's Avatar
Check your throttle body. With the amount of random oil this thing puts out it can gunk it up causing the low idle.
Old Nov 14, 2010 | 10:17 PM
ShaneH85's Avatar
So to clean the tb you unhook the battery, take the intake off, and unbolt the tb from the plemnum? And I guess clean it with carb cleaner? I have heard these things can mess up easy
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
BradMD_96
Oct 6, 2015 09:31 AM
