Side mirror is driving me crazy
Old Nov 18, 2010 | 12:54 PM
pitt_fan's Avatar
why the hell is it so hard to install this fcking mirror
ok the dam black side mirror bracket that holds the mirror broke , si i went and bought a used mirror ive been reading some post about this mirror but dam this is ridiculously hard to do .
any 1 have any instructions
you open up the mirror but then thers the dam wires i dont know what to do
this sucks
helppp
Old Nov 18, 2010 | 01:05 PM
speedracerg35's Avatar
I haven't replaced a g mirror, but I've done a ton of them. You will probably need to take off the door panel and there will probably be three bolts holding the mirror on. The wires should be plug and play. if you bought a used mirror and there is no plug on it, that means they cut the mirror off.
Old Nov 18, 2010 | 01:13 PM
pitt_fan's Avatar
the mirror i bought came with everything nothing is missing ,
thing is its not plug & play ,ok i dont want to cut any wires , thers this white plastic box with 5 little wires going in it i forget whats the name for this box i dont think i could yank these litle wires out thats where im at
Old Nov 18, 2010 | 01:20 PM
Yeah, that's the other half of the plug. The male or female end of the connection is part of the car's wire harness. When you unbolt the mirror on the car, you will have to unclip the same "box" off and plug the new mirror in. There is a diy for removing the door panel in the diy section. There is actually a g35 diy video journal on line for doing various jobs. The link to it is on his board. Search for it. If I can find it I will post it for you.
Old Nov 18, 2010 | 03:01 PM
pitt_fan's Avatar
would i need to tape the wires together ? i c no other way . those wires dont seem to want to come out from the white box i think cutting them and then taping it up is the only way
Old Nov 19, 2010 | 04:32 PM
Shadowslayer's Avatar
How about some pictures so we can see what you are talking about, then maybe we could help you better.
Old Nov 21, 2010 | 05:49 PM
do not cut any wires. the white box you are talking about clips into a harness.
Old Nov 21, 2010 | 06:43 PM
pitt_fan's Avatar
the thing is that little white box with the wires in it wont pass through the new bracket thats why im stuck , i asked a infiniti mechanic if theses wires come out he said yes but i cant remove them . do you know how to remove the wires from the white box so i could pass the wires through and then re insert them in the box . if this wont work then all i got is cutting the wire and reconnect them and electric tape them
Old Nov 21, 2010 | 07:21 PM
thescreensavers's Avatar
Mr.202?
Take pictures.
Old Nov 21, 2010 | 08:22 PM
dumbg35x's Avatar
im not sure but maybe you got wrong one.
heated and power mirror might be different from the non-heated one.
Old Nov 21, 2010 | 08:32 PM
pitt_fan's Avatar
there both non heated i just need to find a way to disconnect the little wires from the wire harness , i think all just bring it to infinti or some garage and tell them to disconnect them , pass it through the bracket , reconnect it and then put on the mirror
Old Nov 21, 2010 | 09:22 PM
dumbg35x's Avatar
take a quick picture so we have a idea of how you are stuck.
Old Nov 23, 2010 | 03:20 PM
pitt_fan's Avatar
ok i brought it to my infiniti dealer they removed the plastic box , so i all is good except for some reason i put it on the bracket and it wont swivel it just stays put i guess its better then nothing if any1 knows why please tell me b4 i install the hole mirror tomorrow thx
Old Nov 24, 2010 | 12:52 PM
pitt_fan's Avatar
just installed the mirror everything is goood thx 4 all the help
Mry
Mar 3, 2023 01:03 AM
Th611
Oct 27, 2015 03:48 PM
mcneil_g35
Aug 5, 2015 12:03 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
emorehs
Jul 17, 2015 09:45 AM
