Why does the passenger window roll down everytime i close the door or lock the car???
Old Dec 6, 2010 | 12:28 PM
Irrelevant's Avatar
Originally Posted by onthe3rdday
In theory this makes sense, but in practice, it's not gonna happen. I was recently concerned about this when my window motor stopped working. I wound the window all the way up manually and closed the door. Then I disconnected the motor harness. The glass has more than enough clearance!
Your glass must be installed relatively low. Mine will rub against the opening at the rear corner if the window drop doesn't function correctly. The door could be opened and closed, but not without putting stress on the glass.
On my car, there is plenty of clearance at the front of the window glass, but not the rear. The glass can be adjusted in the regulator so that the door can open and close without issue, but weather sealing is compromised.
Old Dec 6, 2010 | 09:31 PM
itsgroll's Avatar
Originally Posted by KSWAY
Your window regulator needs to be reset..>>>>>>>http://www.infinitihelp.com/diy/gcou..._procedure.htm
this is for the 03-05 coupe, will this work for the 2006 coupe as well?
Old Dec 7, 2010 | 09:48 AM
Irrelevant's Avatar
It should. It's not as if Infiniti did anything to fix the problem over the five years the g35 was produced.
If one is mechanically inclined, the procedure, including door panel removal, takes about fifteen minutes. If one isn't, it will probably take a half hour.
I've never owned a car before that had such easy-to-remove door panels. It's almost like Infiniti knew owners and service technicians would need to pull them off frequently.
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
whattf
Jul 17, 2015 02:41 PM
